Old 11-11-2005, 07:53 PM   #31 (permalink)
grunge311's Avatar
Originally Posted by Bayou Titan
I'm a "myth buster" type guy and like to see if a particular "technique" will work. Once I killed wasp on a wasp nest that were on the house using a heat gun. The gun will singe their wings and they will drop off the nest. This is difficult however since the airflow of the gun will try to push them away before their wings burn. If you try this, try to aim the gun towards the nest so that the airflow will push the wasps against the nest.
Now, I just improvise and use a can of WD40 with the straw nozzle as a flame thrower. (do not try this yourself, you have to not know what you are doing to do this )
I use the exact same wd40 technique for wasps.
grunge311 is offline   Reply With Quote
