Re: Power Window Motor Removal and Install
I just changed the drivers door window guide assembly on my cousins Titan about a month ago. The cable on his broke too. He bought a replacement from the dealership and it came with the guides and cables all assembled in one assembly without the motor (about $100.00) . All I had to do was tape the window up ( to keep it from sliding down when I unbolted it from the guide) and remove the four bolt that attached the guide assembly to the door and the whole assembly was able to be removed from the lower hole on the inner door skin. After I got it out I took the motor off and bolted it to the new guide assembly and put it back in the door. It was alot easier than I thought it would be. The whole job took about an hour to do.
2005 Titan KC
CST 4" Spindle Lift
PRG 2.5" Leveling Lift
Go Rhino Step Bars
Banks Monster Exhaust
2 Soundsplinter RL-p15's
Elemental Designs Nine.1
Elemental Designs Nine.2X
Elemental Designs Edi 6500's Components
Alpine IVA-D310 In-Dash DVD
200Amp Iraggi Alternator
Optima Red Top
