Old 12-21-2005, 03:38 PM   #1 (permalink)
Seat Spring Noises
My drivers seat has developed a squeek from the springs and was wondering if anyone else has this issue and what have you been able to get done?
I have a 2004 SE Crew Cab bought new last Feb and I only have 5k miles on it (it does not get used much).
vyper340 is offline   Reply With Quote
Old 12-21-2005, 03:46 PM   #2 (permalink)
colding's Avatar
Re: Seat Spring Noises
Turn up the volume on your radio, install a Banks Monster exhaust system and your squeak is gone!
2005 Titan KC XE 4x4
Airaid Intake
JBA Catback Exhaust
Helo Maxx6 17x9's
285/70/17 Nitto Terra Grapplers
"Democracy is three wolves and two lambs voting on what to have for lunch - Benjamin Franklin. "Liberty is a well armed lamb contesting the vote." -unknown
colding is offline   Reply With Quote
Old 12-21-2005, 10:06 PM   #3 (permalink)
Join the crowd! My seat squeaks bad. I'm going to attempt to fix it myself in the Spring- I already had it back to the dealer and all they did was "lube" everything and it didn't fix the problem.
Right now, I just turn the stereo up loud.
2Titans is offline   Reply With Quote
Old 12-22-2005, 05:31 AM   #4 (permalink)
dss90c's Avatar
Are you sure it's the springs? Mine was real bad - squeaked every time my weight shifted. The problem was at one of the rear mounts. I added a thin piece of rubber between the seat mount and the floor and the squeak is gone now.
2005 Smoke CC LE 4x4
Born on Date 3/05
Adopted 5/19/05
OR/BT Packages
Nav & DVD
Mods:
Truxedo Lo-Pro, Parrot CK3100 Bluetooth Hands-Free Speakerphone, Power Tailgate Lock, Zoomers Cannon Exhaust Tip, DEI 561T Remote Start, Line of Fire LED light bar, Backup Camera displayed on nav. screen
EBC Greenstuff pads & rotors, Aux. back-up lights, Wade In-Channel vent visors, keypad entry
dss90c is offline   Reply With Quote
Old 12-23-2005, 07:50 AM   #5 (permalink)
I'll check into the suggestions and turn up the radio in the meantime... Let me know if you come across any other good fix.
Old 12-23-2005, 08:41 AM   #6 (permalink)
CoachBoone's Avatar
Mine is terrible. Dealer replaced the base, did the magical lube thing, none of it helped. I think I've talked him into replacing the whole seat.
2004 Nissan Titan SE 4X4 Crew Cab
with a bunch of stuff on it.
"Straighten that tie, son."
Old 12-24-2005, 03:06 AM   #7 (permalink)
Truck41's Avatar
this may help you guys, the squeek noise is most likely, coming from the seat mounts. loosing them up, and spray WD40 on them, that cured my noise.
06 titan 4x2. LE. Granite.
zoomers exhaust tip.
factory chrome wheels.
hellwig swaybar.
carriage works grill.
armada spoiler.
trueflow intake
Goodyear eagle GTll
Truck41 is offline   Reply With Quote
Old 12-24-2005, 06:17 PM   #8 (permalink)
Send a message via AIM to GreenT
I will have to try and lube the mounts. Mine drives me nuts even with the Banks and the radio up loud Probably be better off using a lubricant rather than a penetrating oil on the mounts though.
05 Deep Water Blue KC SE
Rockford pop package w/ buckets, Traction package, Utilitrac w/ bed extender, Banks exhuast, Volant V3
GreenT is offline   Reply With Quote
towing horrible noises? fastTitan Titan Problems & Dealer Service 5 05-31-2005 05:52 AM
bed noises MemTitan Titan General Discussion 14 03-27-2005 06:02 PM
noises with subwoofers installed mbjkiller Titan Interior Discussion 6 11-10-2004 11:29 PM
