Old 01-01-2006, 09:00 AM   #1 (permalink)
Radio Mute Wire
I will be installing a bluetooth car kit for my cell phone in my 05 cc le with rockford system. i was wondering if anyone knew where the radio mute wire was so i could hook up the car kit to mute the radio whenever i recieve a call. thanks in advance
05RedLeCC is offline   Reply With Quote
Old 01-01-2006, 11:11 AM   #2 (permalink)
Sammy Sandbag's Avatar
Re: Radio Mute Wire
From what I can decipher from the AV SM, is that there is no individual mute wire. The HU uses a RX/TX two wire setup between it and the face plate and the only functions with their own wire are the Eject and Load buttons.
-Counsel Yourself
2009 Blizzard Pro-4X
Old 01-01-2006, 06:27 PM   #3 (permalink)
dss90c's Avatar
Re: Radio Mute Wire
There is a wire going to the RF amp (I believe from the HU) - It is called AMP ON. Breaking this wire kills the amp. I used a relay with the mute signal from my Parrot bluetooth to break this wire, which "mutes" the radio. Here is the detail from the SM It's wire 9.
2005 Smoke CC LE 4x4
Born on Date 3/05
Adopted 5/19/05
OR/BT Packages
Nav & DVD
Mods:
Truxedo Lo-Pro, Parrot CK3100 Bluetooth Hands-Free Speakerphone, Power Tailgate Lock, Zoomers Cannon Exhaust Tip, DEI 561T Remote Start, Line of Fire LED light bar, Backup Camera displayed on nav. screen
EBC Greenstuff pads & rotors, Aux. back-up lights, Wade In-Channel vent visors, keypad entry
dss90c is offline   Reply With Quote
Old 01-01-2006, 08:11 PM   #4 (permalink)
Re: Radio Mute Wire
Now that's pretty clever. Good thinking.
-Counsel Yourself
Old 01-02-2006, 05:04 AM   #5 (permalink)
mhwo's Avatar
Re: Radio Mute Wire
I used a relay with an IC timer to mute the radio. The way I did it was to build a circuit that takes the mute signal from the Parrot (or any other muted bluetooth) and throws the relay momentarily. The output of the relay is soldered across the 'mute button' on the control head of the radio panel. When the signal goes to mute, the system acts as if I hit the mute button manually. When the system returns to normal, the relay again shorts the pushbutton on the panel momentarily and unmutes the system. Works pretty good.... All Radio Shack stuff and cost about $14.00 and my time.
mhwo is offline   Reply With Quote
Old 01-02-2006, 12:44 PM   #6 (permalink)
Re: Radio Mute Wire
so how do i do this? i wouldnt consider myself a beginner when it comes to installing car stuff i would consider myself a novice. what is the easiest way for me to do this? can i just tap into the wire which comes from the mute button on the HU? or is there a specific wire i need to find
thanks
Old 01-02-2006, 01:04 PM   #7 (permalink)
dss90c's Avatar
Re: Radio Mute Wire
There is no wire from the mute button. mhwo soldered onto the circuit board. To use the AMP ON wire like I did, you can find the wire in the bundle from the RF amp (behind the gas pedal). The bundle comes out towards the front of the dash. This is where I was able to locate the wire.
Born on Date 3/05
Adopted 5/19/05
OR/BT Packages
Nav & DVD
Mods:
Old 01-02-2006, 05:25 PM   #8 (permalink)
mhwo's Avatar
Re: Radio Mute Wire
To clarify a little, when u push the 'mute/pause' on the front panel, you are closing a switch that goes through a logic circuit that turns the audio down/off. It is not a switch like when turning a room light on and you need to be careful how you use it so as not to damage the circuit board or circuits on the panel. In essence, I use the mute signal (which is ground) on the car kit to complete a circuit to a relay (Radio Shack) and it acts like me pushing the mute on the radio. The trick is not to have the switch constantly on. That's why I use a circuit that triggers the relay for only 1/2 second.
Old 01-11-2006, 09:56 PM   #9 (permalink)
Re: Radio Mute Wire
mhwo - any chance you would share a parts list and/or schematic of your mute button solution?
JennaSys is offline   Reply With Quote
Old 01-13-2006, 06:47 AM   #10 (permalink)
mhwo's Avatar
Re: Radio Mute Wire
Its an easy build, but if its something you have never done before, it may be a pain. Here is the schematic.
All parts available at Radio Shack. Where the switch is indicated on the schematic, put the mute out wire from the phone. Take an output from the relay and solder the 2 leads across the mute switch on the front panel. I used a Radio Shack relay. It's a 12vdc miniature DPDT. I have an engineering background, so it was easy for me. I offer no warranty or help other than whats posted here, so good luck.
Old 01-20-2006, 03:52 PM   #11 (permalink)
Re: Radio Mute Wire
Awesome - Thanks for the schematic. It saves me from having to do a bunch of experimenting. I've actually got most if not all of these parts laying around in a box somewhere from back when I was techno geek. Um, oh wait, I guess still am...
Old 02-11-2006, 07:17 PM   #12 (permalink)
Re: Radio Mute Wire
I did the same as DSS90c. It works great. Thanks to all who contributed to this thread.
jhaley007 is offline   Reply With Quote
Old 02-11-2006, 08:05 PM   #13 (permalink)
Re: Radio Mute Wire
I dont suppose you would be able to "dumb this down somme." I am moderately familiar with what is going on in your diagram, however when you say you cross the Mute button...what do you mean? I am fairly brave with what I will try and for something like this I would be willing to give it a try.
TIA
'05 Titan KC SE 4x4 - Canteen - BOD 3/05 | K&N CAI
usulsuspct is offline   Reply With Quote
Old 02-14-2006, 11:24 AM   #14 (permalink)
Elbo's Avatar
Send a message via MSN to Elbo
Re: Radio Mute Wire
Thinking about getting a Parrot.. (hmm that sounds strange)
can this be made to work with the 6 disc, non-RF radio?
Elbo is offline   Reply With Quote
Old 02-19-2006, 10:23 PM   #15 (permalink)
mhwo's Avatar
Re: Radio Mute Wire
TIA
The mute button is a momentary contact switch on the circuit board that holds all the control buttons such as the CD, SAT etc. The idea of the circuit is to do what your finger does when you hit the mute button. So the 2 wires in the diagram that are labeled 'to mute' are simply soldered to each side of the button labeled mute on the circuit board.
Parrot Mute Wire Question mhwo Titan Visual & Audio Discussion 3 12-16-2005 01:04 AM
Using Radio Mute Button mhwo Titan General Discussion 1 11-23-2005 11:00 AM
Reverse wire harness- Orange/black wire? BIGT56PA Titan Visual & Audio Discussion 6 09-14-2005 04:51 PM
phone/radio mute with nav StvMLNJ Titan Interior Discussion 0 02-12-2005 09:21 PM
cell phone car kit / radio mute 40-Dan Titan Interior Discussion 3 09-29-2004 08:32 AM
