Old 01-15-2006, 01:31 PM   #1 (permalink)
Marc's Avatar
Send a message via AIM to Marc
Back-up Sensor Problem. Any ideas?
So I put my truck in reverse today and the back up sensor is just doing a constant beep. I thought maybe there was something on one of the sensors so I whiped them off, but still the constant beep. It didn't do this before I installed my Satellite radio. Do you think that the wire for the antenna is causing interference under the dash, or due to the weather? It was raining all day yesterday, then turned to freezing rain/snow. Could the wires be frozen in back??
2005 Titan CC SE 4x4 Radiant silver
Big Tow Pkg
Line-X Spray in bed liner
Active Tuning Ground Kit
Chrome Tailgate Trim
Recon Line of Fire and Ice
Weathertech In-channel visors
Weathertech floorliners
Sirius Satellite Starmate Replay
www.nenoc.org
Marc is offline   Reply With Quote
Old 01-15-2006, 03:24 PM   #2 (permalink)
Re: Back-up Sensor Problem. Any ideas?
I had the same thing happen today. I think it had to do with the cold and the quick freeze we had last night.
Tom
05 Titan SE CC 4X4 | Deep Water | Big Tow
Pop Pkg | Utilitrack w/ extender & divider
Born on 2/05 Mine 4/05
A.R.E. LS II added 6/05 | Step Rails added 4/06
TitanTom is offline   Reply With Quote
Old 01-15-2006, 03:52 PM   #3 (permalink)
Marc's Avatar
Yea I actually shut ut off...I figured that was all it was, but just wanted to get some opinions
Big Tow Pkg
www.nenoc.org
Old 01-15-2006, 06:06 PM   #4 (permalink)
PTitan's Avatar
Need more information: Vehicle kept outside or inside, heavy rain, cold temperature, etc. One possibility, if the vehicle is kept inside and the change in temperature, from going from inside to outside, create condensation on the inside of the sensor, could lead to sensor activation. Other possibility is that you may have a sensor that has not been sealed properly and moisture condensed inside. Now if the assumption is that the satellite radio may affect the sensor. One way to rule out is to disconnect the satellite radio for a short while and see if condition persists.
PTitan is offline   Reply With Quote
Old 01-15-2006, 06:17 PM   #5 (permalink)
jtheaverin's Avatar
I have the same problem when the temp. is below about 20 degrees. They beep constantly when in reverse. When the temperature goes up the problem goes way. Others have posted the same problem.
jtheaverin is offline   Reply With Quote
Old 01-15-2006, 08:03 PM   #6 (permalink)
scr38's Avatar
A light coating of frost or ice on the sensors will cause this. Push the button to turn off the tone.
Old 01-15-2006, 08:19 PM   #7 (permalink)
cuba65's Avatar
Marc, same thing happened to me today. Here in Connecticut we also had heavy rains then a quick drop in temperature last night, everything froze up.
Back up sensor had a constant beep while backing up all day, also had a rear door not opening all the way. Everything back to normal tonight.
cuba65 is offline   Reply With Quote
Old 01-15-2006, 09:45 PM   #8 (permalink)
grunge311's Avatar
Its usually frost that sets them off like that. just wipe them off with your finger and it works.
grunge311 is offline   Reply With Quote
Old 01-15-2006, 10:19 PM   #9 (permalink)
pi3yeargrad's Avatar
Good thing we dont get frost or snow here...last year it snowed here for the first time in like 90 years or summing like that and on christmas day at that (04 christmas)
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 01-16-2006, 04:44 AM   #10 (permalink)
Banned
Boot Man's Avatar
I had the same problem in Southeastern MA. Wiped and windexed the sensors, still beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep.
waited until nighttime, beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep.
Colder today, time to visit dealer. I paid for it, they should make it work.
Boot Man is offline   Reply With Quote
Old 01-16-2006, 05:36 AM   #11 (permalink)
Marc's Avatar
I wiped the sensors this morning, and still the beep...I am going with the weather related issue...PTitan: It is kept outside..we had heavy rains, then it suddenly dropped in temp over night to freezing...now temps are in the 20's.....not including the wind chill. I am thinking of spraying some warm water on them to see if that works...otherwise, to the dealership it goes.
Big Tow Pkg
www.nenoc.org
Old 01-16-2006, 05:38 AM   #12 (permalink)
Marc's Avatar
Boot where are you located?
Big Tow Pkg
www.nenoc.org
Old 01-16-2006, 05:54 AM   #13 (permalink)
Banned
Boot Man's Avatar
Whaling City
Old 01-16-2006, 06:01 AM   #14 (permalink)
Mr. B's Avatar
Back-up sensors....HA!....I look in my mirrors just like my daddy did and his daddy before. The more crap they pile on these trucks, the more femanin they become. I $hitcanned the tire pressure sensors and would have probably done the same with the back-up sensors had I not been such a cheap-skate when I bought the truck in the first place. I still make excuses about Titans ONLY having an automatic trans. when my buddies laugh and remind me that I called THEM "nancy-boys" when they showed up with new, optioned out trucks. When I called up my best bud and told him about my new truck, he said, "automatic? Did it come with panty lace interior?". Uhhhh, were was I?....oh yea, good luck with your back-up sensors.
SexySilver 2004 XE KC, Magnaflo, K-N drop in, butchered stock box, 18" 6 spoke LE wheels and Goodyear SR-A's, 80k miles
Mr. B is offline   Reply With Quote
Old 01-16-2006, 06:01 AM   #15 (permalink)
Marc's Avatar
Whaling City
HA...ever get over to East Bay of RI?
Big Tow Pkg
www.nenoc.org
Back up sensor problems? BLoch Titan Problems & Dealer Service 15 06-23-2006 05:15 PM
Tranny Problem - Any Ideas? comperk Titan General Discussion 7 12-10-2005 09:18 AM
Tire Sensor problem kartman Titan General Discussion 4 10-17-2005 04:53 AM
Dog in The Back...Any Ideas??????? Davink Titan General Discussion 32 05-27-2005 02:30 PM
4WD Problem - Ideas? bluesun Titan General Discussion 8 04-25-2004 09:37 AM
