I have a 04 SE and would like to put a trip computer thing I have in the space between the front sunglass holder and the next compartment. Right now there is a blank plate there. Can this be removed without taking the console off the roof or breaking anything?
Thanks,
Loran
2004 Nissan Titan KC SE 4x4 with Big Tow package- Zoomers exhaust tip, Rear-view screen in sunglass pocket, scanguage intergrated into overhead console, power tailgate lock.
1982 Delorean DMC-12 Turbo (Vin #10696)
2000 Toyota Camry CNG Powered
1999 Forest River Sandpiper 21R 5th wheel trailer
If you are talking about the blank that is at a slant to the floor in front of the "sunglass holder" and the map lights, then yes. It takes a bit of carefull prodding, but it will pop out. If memory serves me, you will have four molded clips. Not the pop off kind, but molded with the piece. I took a thin bladed pocket knife and started at the corner, and worked my way around. I am thinking about flush mounting my XM commander control there.
2008 Crew Cab SE Long bed 4x4
Timberline Green Exterior
Almond Interior
Mod's: LiquidMetal Wingman wheels, Parada Spec-X tires, N-Fab 6-step Nerfbars, Sliding OEM Toolbox, AVS Vent visors, Tint, CUSTOM One-Off JesHand Creations Front Stealth Bumper, Tailgate bib Cover, color matched steering wheel wrap, Chrome swap on mirrors and door handles, PRG 1.3" Level kit
Yeah, She's the Biggest One
General James Mattis, USMC to Iraqi tribal leaders.
"Allies or enemies. You make the call. I come in peace. I didn't bring artillery. But I'm pleading with you, with tears in my eyes: If you Faq with me, I'll kill you all."
exactly what I needed thanks! I'll post a picture once the scanguage is mounted if it looks good.
is it much trouble fishing the cable accross the roof and down the A pillar? i presume that is the path you took to the ODBC port.
No it wasn't too bad (unless you have side airbags). Just 2 screws to pop off the A pillar and just loosened the overhead console enough to fish the cable to the winshield. Then shoved the cable into the space between the headliner and windshield. I did have to make an extension cable; cut the connector off and just used a cat5 (ethernet cable, 8 wires) and rj-45 connectors and couplers to join it all together.
The worst part was cutting the top and bottom off the scanguage so it would fit in the overhead console opening.
wow, like the cat5 connector idea, I just wouldn't have thought of that.
__________________ Firefighting - I fight what you fear.
Titan LE 4WD O/R B/T 2005
Red Alert
Banks Ex., Brush Guard w/ 4 O/R , Street Pilot GPS, Fire Department Emergency lights, Emergency Siren, Bed extender, Overhead bed rack, safari basket, K&N Cold Air intake, XM Radio, Cobra all-in-one CB, short glass mount CB antenna, Firefighter Maltese cross hitch cover, remote roll up windows, auto door lock/auto unlock from KP Technologies, TB Spacer, Grounding kit
Just Added: Invisible front bra 3M, Valet remote starter
Soon to come: Over head switch panel for Emergency FD lights and off-road lamps, lift kit of some sort, fender flares, power tailgate lock, power bed box lock
Thats a great job on that scan gauge in your overhead console. My 05 SE has a compass/temp in that slot, so it wouldn't work on mine. I put mine where the NAV would have been on top of dash. But it is too big for that area for looks. Anyway, the scan gauge is nice to have, too bad it wasn't smaller.
