Doesn't sound like it working ....I find it difficult to understand the rapid temperature jump just by passing. have you even heated oil....It takes a while to loose the heat. Your post indicates you can regulate the heat generated with your throttle pedal.
Almost sounds like the probe is not in the grease. Maybe the probe is to high. Never mind I looked at the pic, and if it isn't in the grease he will have a big problem.
Mr. Haney, I don't if you noticed but, I have an aluminum diff. cover that has 3/4 quart more capacity than OEM cover. So I think, and I may be wrong, that helps the oil cool faster. Also I think the oil heats up because of the load on the gears and bearings when accelerating.
Temp sounds about right. I shot my old rear end (with one of those temp guns) after towing my boat 30 miles and it said 230 on the old Pumpkin. Now with the new 05 rear end it reads about 215 after a short tow.
2004 SE CC Deep Water 4x2 BT
Nismo CAI, Zoomers exhaust,PRG leveling kit, PRG traction bars,OEM step rails, Nissan fog lights, ARE LSII cover,New 2005 rear end, Active tuning grounding kit,Black powdercoated "stubby" antenna,Weather tech vent-visors (front only), Armada air dam, PIAA back up lights, chrome tow hooks, Air Lift "Ride Control" Air bags, AMP Research power steps, TrueTrac, Mag-Hytech diff cover, A-Pillar 3 gauge pod,Custom painted engine cover by Scottsbro23
Looks nice, but I don't think it is heat that is making the rears fail.
If heat is not a contributing factor then why did Nissan change to a diff cover with cooling fins and switch to synthetic lube, where the main advantage is withstanding higher heat levels without thermal breakdown?
I agree Beltbuckle. And thanks for your input Krh2. And I'm not trying to start an argument, just want to hear everybody's thoughts. I respect you all.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
It would be interesting to have someone else report who also has a guage installed on the stock diff cover. And towing temps.
Getting too hot = loss of lubrication = more friction = metal failure. But so far your temps seem fairly normal.
If my stock finned cover had an access hole like the pml cover I would install a temp guage. To much of a wimp to try to tap one myself.
I wonder if the Nissan Diff cover extends out far enough so that the sending unit does not touch the gears. The PLM cover is 2 inches deeper than Nissan cover.
220 does sound a bit warm for just riding around town. I did some monitoring a while back with surface mounted RTDs and got some good readings. Never saw higher than about 210 degrees.
Silver 4x4 SE CC, Born 3/04
Graphite Titanium
Off Road/No Locker, BIG TOW/VDC
Step Rails, Truxedo,
Gibson Cat Back, AEM Brute Force CAI
Hood Protector, Tinted Windows
My other car is a diesel
(02 VW Jetta TDI, 49 MPG)
Interesting, cttitan. I wonder if the difference in temp. readings is because your readings are only surface and are affected by the air flowing around the surface. I'm sure the temp. is warmer internally.
