Go Back   Nissan Titan Forums > Titan Discussion > Titan Interior Discussion
User Name
Password
iPod Integration install instructions - being discussed at Nissan Titan Forums in the Titan Interior Discussion section.
Old 02-19-2007, 05:34 PM   #16
kgMoto
Re: iPod Integration install instructions
rvandam:
You were only one step away from the instructions you are looking for actually.
Go here:
courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Product_Cod e=999U7-IPDNOST
Then scroll to the bottom - you can download the install instructions in .pdf form from a link right there.
(and thanks; I didn't realize you could buy this kit separate - this is great)
and redrum94 - I highly recommend staying away from the FM transmitters like the iTrip. If you're not that into audio quality, then it's ok, but otherwise, hook it up direct through the Aux input port right there in the front. Like someone else said, just grab a $6 3.5mm stereo cable and put the deck on AUX; it'll work fine.
kgMoto is offline   Reply With Quote
Old 02-26-2007, 03:22 AM   #17
redrum94
Send a message via AIM to redrum94
i cant get my aux port to work...dont know if it is the port itself or my Ipod maybe needs an update!! my truck is going in for the final fix on the brakes so i will have them take a look at that too!!!!!!!!!
thanx guys
redrum94 is offline   Reply With Quote
Old 02-28-2007, 05:04 PM   #18
opulence
Originally Posted by TexTheTitan
Where did you get the iPod integration kit?
Also, what part of Atlanta are you in? I'm in the South Forsyth Area and would like to get some of us Titan owners togther sometime.
I just moved from Villa Rica to Stone Mountain and would be happy to be apart of a Titan get-together for the Atlanta area.
opulence is offline   Reply With Quote
Old 02-28-2007, 06:53 PM   #19
Carbon
Carbon's Avatar
The ipod intergration kit from the dealer is so easy to install. Its a box and one cable. All you do is plug a wiring harness (male plug) that you find under the drivers dash, next to the steering colum and plug it into the box. Then take the included cable whichs plugs into the other port (of the box) and plug it into your ipod. The cable is 6ft or so, so you can run it to your center console as I did. Super easy and you still have sterring wheel control (limited tho)
Carbon is offline   Reply With Quote
Old 03-20-2007, 10:44 AM   #20
2006TexasTitan
My AUX jack didn't work either. I must have been doing something wrong. I tried several times but just couldn't get it to work. Can anyone offer some help?
2006TexasTitan is offline   Reply With Quote
Old 05-06-2007, 08:48 AM   #21
inqui-Z-tor
inqui-Z-tor's Avatar
Can anyone scan/email me a copy of
Quick Reference Card
Owners Manual
Service Info Insert
Critical Installation Info
None of these were left .. when the dealer installed the iPod interface in my Armada.
"inqui-Z-tor" because I ask questions
inqui-Z-tor is offline   Reply With Quote
Old 04-06-2008, 02:59 PM   #22
900King
900King's Avatar
Where is the cheapest place to get the interface cable? Is the dealer the only place right now? I think $150-200 is outrageous.
Thanks,
J
900King is offline   Reply With Quote
Old 04-20-2008, 10:00 PM   #23
Titan Izzey
Titan Izzey's Avatar
did you install the ipod kit yet? if so how long doid it take you to install?
Titan Izzey is offline   Reply With Quote
Old 04-24-2008, 10:49 AM   #24
Jerrygfd
Jerrygfd's Avatar
I installed mine after making a purchase from a Nissan Dealer. Easy installation and I connected the main cable to the male connector located in the steering wheel column. You really can't sort music or select specifics from the steering wheel controls but from the radio console buttons. As mentioned in another thread the wheel controls are limited. I put mine in the glove box and its out of site. Overall satisified and a lot better than the auxillary jack.
2004 Smoke Color SE 4 X 4 Crewcab fully loaded with Off Road Package, Popular Pkg, Util Pkg, Big Tow Pkg, SplashGuards, Floor Mats,
I installed after purchase: *Dealer installation
Bug Deflector,
Wade Window Vent Visors
Westin Platinum Step Rails
Carriage Bolt Billet Grilles Upper and Lower
Stillen Dual Rear Straight Exhaust Part #509547*
K&N 77 Series Polished Alum Air Mod Kit #6012KP*
Trailmaster Front Coil Spring Leveling Kit #NL220*
Husky rear floor mats
TruxedoTonneau Lo Pro Cover
Prodigy Brake Controller
IPOD Interface Kit
Firestone Ride Rite Air Bags part #2355
Towing on vacations: 2008 Keystone Hideout 28'
Model 27B Travel Trailer with Eaz-Lift 1000/14000 WD and Robins Sway Bar.
DR Rear shocks
Future Mods: Front SAWs coilovers
Jerrygfd is offline   Reply With Quote
Old 04-24-2008, 12:38 PM   #25
ablexus
ablexus's Avatar
Send a message via AIM to ablexus
For the suggestion of the radio adapter: our aux jack is a billion times better than that option. I can't believe that this technology wasn't in all cars for the last 20 years... there's an aux jack on my 15 year old boom box. The radio adapter sound is horrendous, and I'm not even an audiophile.
How do you turn on your ipod when it's in the glove compartment? How do you turn it off? How do you advance songs? How do you select AUX with the steering wheel?
Andrew
Here's my truck and an angry little force-fed 4-banger:
I'm looking for a chrome bug shield and a sub box for under the rear bench seat. Please PM me if you have one / know where one can be located.
ablexus is offline   Reply With Quote
Old 04-25-2008, 01:51 PM   #26
Titan Izzey
Jerrygfd,
Did you remove the dash and glove box to install it, if so how long did that take and was it hard?
Old 05-03-2008, 11:07 PM   #27
mcclintock89
i gotta few questions. i just glimpsed over the forum so i'm sorry if i didn't read this elsewhere. is this a full speed connector and does the information display right on the cd player? and also idk if i have satelite or not i have the sat button on my cd player but whenever i push it it just says unavailable. also is this compatible with the rockford fosgate system?
mcclintock89 is offline   Reply With Quote
Old 05-08-2008, 08:39 AM   #28
Titan Izzey
yes it is compatible with the rockford fosgate system
User Name
Password
Ipod Integration Kit Tonka Titan Titan Visual & Audio Discussion 64 02-01-2008 11:29 PM
Living with the iPod integration kit. rael Titan Visual & Audio Discussion 6 11-05-2006 03:33 PM
Need PRG Install Instructions MXTitan Titan Suspension 3 12-14-2005 06:26 AM
IPOD integration with Nissan Factory stereo and controls DjKamper Titan Visual & Audio Discussion 11 07-21-2005 09:52 AM
K-Cover install instructions TulsaTitan Titan Parts & Accessories 8 05-17-2005 05:07 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
