Old 12-28-2006, 08:13 PM   #1 (permalink)
Leather seat wear
Just curious if it is common to have the leather start loosening up from the seat cushion after a few miles? Mine is an 05 with 11K and I use Meguiar's about twice per month.
It is difficult to tell in the photo but the leather is starting to get loose.
Also--I have not used Scotchgard or any water-protector/repellent on the seats.
thanks
white
whiteLE is offline   Reply With Quote
Old 12-29-2006, 09:35 AM   #2 (permalink)
Vector's Avatar
Re: Leather seat wear
That looks pretty normal. Mine did the same thing. I have had the drivers seat back replaced due to excessive ware. After about 20K miles mine was chafing and looked well worn on the drivers outside side bolster. Nissan replaced it under "Good Will" stating that it was normal ware but they wanted to keep me happy. But when the new seat back arrived it had a much looser fit than the original. I believe that the originals were stretched too tight, causing excessive ware due to no give in the leather.
2004 Titan 4X4 LE Crew Cab
K&N Gen 2 FIPK
2 degree timing advance
Nismo Pedals
Sirius Satellite Radio
Monochromatic White Front Grill Surround and step rails
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Vector is offline   Reply With Quote
Old 12-29-2006, 12:12 PM   #3 (permalink)
BKW
That's not wear...that's normal expansion of the leather.
BKW is offline   Reply With Quote
Old 12-29-2006, 04:44 PM   #4 (permalink)
thanks for the input--I just hate looking and sitting on something that looks like a football that's been in the lake.
should I wait awhile for it to get worse and then complain to the dealer?
did you guys do scotchgard/water protection on your seats?
white
Old 12-29-2006, 07:07 PM   #5 (permalink)
ruauman2's Avatar
I just had the driver side seat bottom replaced this week. The seat edge where the a$$ first meets the seat had some small cracks. It was very minor. The dealer looked at it and said "no problem". I also got the tow harness fixed and the fuel sending unit replaced. My gas tank actually reads full when it is full.
If it bothers you, ask the dealer to fix it on your next trip there. The worst that can happen is they will say "no".
If I hear the lyrics to "Macarthur Park" one more time, I swear to God I'm gonna go postal!!!
ruauman2 is offline   Reply With Quote
Old 01-02-2007, 06:32 PM   #6 (permalink)
Justintoxicated's Avatar
The worst that can happen is they will replace the seats and break/destroy all the clips that hold the wires in place under the seat.
Well thats what happened to me...
They tried to tell me it's not a big deal it will still work fine (with all the wires hanging and rubbing on my amplifier under the seat.
Made them fix it but I know some of the clips are still broken because they are part of the plug connectors, and I'm pretty sure they didn't solder up new connectors in 20 minutes...
In my case I wish I had not had them replace the seat, I think they did more damage than repairs.
Old 01-02-2007, 06:40 PM   #7 (permalink)
yscty's Avatar
If you use the butt warmers that will also contribute to this.....
yscty is offline   Reply With Quote
Old 01-02-2007, 08:29 PM   #8 (permalink)
Clint's Avatar
The seats are more vinyl than leather and I think Nissans poor excuse for leather seats suck. I wish there was a way to have a class action suit for theft by deception. I paid for a leather interior and got sh*t instead. I would have paid a few hundred dollars more to get what I want.
Next Nissan is an SE instead of an LE and I'll have leather seats made. I want the ENTIRE seating surface to be leather, like in the old days. You used to be able to smell the leather.
Clint
You have two choices in life:
Old 01-10-2007, 12:39 PM   #9 (permalink)
Elbo's Avatar
Send a message via MSN to Elbo
I had Katskinz leather put in on my SE, It's holding up really well.
Elbo is offline   Reply With Quote
Old 01-10-2007, 03:46 PM   #10 (permalink)
Nissan "leather" seats are a bit of a sham. I had an 01 Maxima SE with leather and the side bolster on the driver seat started to crack. I took it to the dealer and they sent me to an upholstery shop to get the panel replaced. The upholstery guy said " that's not leather...that's vinyl..we can't fix it."
Apparently Nissan likes to use a leather center panel with vinyl sides on the seats of their leather interiors. It looks the same ...but wears at different rates.
06 Titan White Crewcab LE 4X4, Banks Cat-back, Volant CAI, PRG leveling kit, Bilstein rears, PRG Off-road traction bars, 33x12.5x18 Toyo Open Country M/T's, XM satellite, HID headlights and fogs, SE Offroad skidplate, Trutrac Rear Differential..........SOLD
2007 Armada LE 4x4
2007 G35 6spd sedan
g356gear is offline   Reply With Quote
Old 01-19-2007, 12:18 AM   #11 (permalink)
Leadsled124's Avatar
Clint
I agree, the "leather" isnt very nice in the titans. but the cloth feels like rat hair compared to my gmc sieera i traded in. i actually read in consumer reports or one of those mags that the titan are made with leather front seats and "simulated leather VINYL" in the rear. What the @%&%! the sticker said leather! start the lawsuit im in. My next one too will be bought with cloth and i could get 100% nice leather for prob the same cost as the dealer upgrade. and in my choice of color too! Leather...i say Pleather...
Leadsled124 is offline   Reply With Quote
Old 01-23-2007, 11:17 PM   #12 (permalink)
mbjkiller's Avatar
Send a message via AIM to mbjkiller
2004, 26000 miles, mine looks like this. Taken care with Zaino Leather Dressing or Poorboy's World Leather Dressing.
mbjkiller is offline   Reply With Quote
Old 01-25-2007, 01:52 PM   #13 (permalink)
If you read the actual description of the leather seats, you'll notice most brocures etc state "leather seating surfaces" not "leather seats" the difference being leather seating surfaces are generally the area your but and lower back touch, the rest is vinyl. In many cases the vinyl is cheaper than the cloth. Most rear seats are all vinyl. Vinyl runs about $7 per linear yard for Nissan and the leather they spec runs about $18 per linear yard. Based on the vinyl savings over cloth, I would almost expect the cost per vehicle to be the same. This just tells you how much more profit they make on the LE's.
Missing Link is offline   Reply With Quote
Old 01-25-2007, 02:49 PM   #14 (permalink)
Timster13's Avatar
HaHa!!!
Where can I get the rat hair seat covers? They sound warm and it's cold outside.
My Fast is not concerned with gas mileage...
2006 Crew Cab LE 4x4
(2005 Lemon is gone...)
Smokin Hot Smoke Color
Step Bars
Big Tow
Creative Zen MicroPhoto Player (Screw iPod)
Undercover Tonneau
Nissan All Weather Matts
Timster13 is offline   Reply With Quote
Old 01-25-2007, 05:09 PM   #15 (permalink)
Originally Posted by Timster13
HaHa!!!
HAHA ok let me check my mouse traps when i get home, a few more and ill make a seat!lol
'06-Uprev/Stillen Longtubes/JBA Kat-bak/Injen/highflows/PGM/Trutrac...
Leather Wear Hammerhead Titan General Discussion 6 01-22-2006 06:16 AM
For those considering the leather seat mod. Jamesn Titan Interior Discussion 0 08-11-2005 03:09 PM
Leather Seat Colors? smoketitan Titan Interior Discussion 2 04-09-2004 01:40 PM
Leather seat care? SmokeyStog Titan General Discussion 6 03-26-2004 10:15 AM
