Where to Mount XM Unit (not the factory) and Antenna?
Hey, I am trying find a place to mount the unit and antenna. I was wanting to place the antenna on the roof in front of the brake light and run the wire throw the brake like. How do I get the brake light housing out? I know there are two plastic pieces in the ceiling, but do they just pull out to reach the screws? Also, where is the best place for the XM unit? And, where can is the easiest place to find 12V? Is there anything in the overhead console?
I know these question have been asked many time before, so a link would to a thread would be nice to.
Re: Where to Mount XM Unit (not the factory) and Antenna?
id say mount it in the spot where tha nav screen would go if u dont have one ....
Smoke KC 2WD LE
BIG TOW
mods:
Custom Super 40 True Dual Exhuast
AEM Brut Force Intake
Poweraid TBS
4 Piece Billit Grill
Lund AVS BugShield
85K HID's
Smoke L.E.D. 3rd Brake Light
2*Timing Advance
$22 Helper Spring mod
Jumper Mod (fog running light)
Front Air Dam
Chrome Halos
I used the Bracketron bracket i bought for less than $20 bucks, Then added the PAC Audio convertor to run the XM and my IPOD.
San Diego, Cali. 2006 Nissan Titan LE CC 4x4 PICS
6" ProComp Kit, DR Coilovers, Total Chaos UCA's, Fox Reservoir Shocks. MotoMetal 954 20x10, Toyo Tires.
Stillen Big Brake kit, AMP Research steps
I went through the third brake light like TextheTitan said. Heres a couple pics. If you need anymore info that you can't find in other threads, let me know.
__________________ Smelly Whore™ I bring nothing to the table whore®
2006 Silver Titan K/C LE 4X4 w/Big tow, BFGoodrich All-terrain TA KO 285/65R18s, 77-6012KP K&N air intake, Volant exhaust, Stainless Lund bug deflector, Stainless billet grille, Stainless tailgate bezel, Jettech's rear leaf helpers, XM Skyfi2, Retrax bed cover, Front windows tinted at 35%, 6000k HID low beams Add Kenny Blankenship to your ignore list: it's fun, easy to do and a better use of your time
I assume you have either the Rockford or 6CD (non-RF) unit. I have the Rockford and use an XM commander. The antenna I mounted on top of the rearview mirror using double sided tape and routed the antenna wire just under the the edge of the roof trim, down the pillar next to the windshield on the drivers side, under the dash, down to the floor and under the mat to the area under the drivers seat where I sat the receiver box.
The control head is mounted just above the air vent on the drivers side of the center console using doudble sided tape. I connect audio to the AUX using a radioshack purchased right-angle connector. The audio leads, DC wiring and control head wire is routed under the edge of the center console to the receiver box under the seat.
To find a convenient source of DC power, look under the dash for the factory installed connector for the Nissan satellite receiver. It is located just above the brake pedal. That connector has both switched and constant 12 volts. Use a voltmeter or consult the factory manual to find the appropriate pins.
The antenna can be mounted on the roof, routing the antenna wire through the cabin brake light, but it is much simpler and almost as good reception mounting on the mirror (I have done it both ways and prefer the mirror mounting)
Mine is similar to Kenny's, but I like the antenna centered over the brake light.
__________________ 04 4X4 LE Crew Cab, Purchased Used 3-06, Sold 3-09
Gone, but not forgotten!
Without Trucks, America Stops
If you got it, a truck brought it.
"Don't waste your breath to save your face, When you have done your best,
And even more is asked of you, Fate will decide the rest" --The Grateful Dead
"I've seen too much not to stay in touch with the world made of love and luck,
I've got a big suspicion about ammunition, I never forget to duck" --Jimmy Buffett
For those with the "SAT" option on the stereo, what kind of connector do I need to do a direct connection with my tuner? (I haven't taken apart my dash yet to see). The BestBuy salesman yesterday told me that I had to buy it from the dealer (ugh). Upon my visit to the dealer today, I was told all they had was a tuner that plugged into the back (enabling me to use the OEM head unit), but he didn't have any additional details except for a $300+ price tag for the equipment. Suggestions?
2005 S/C Elise
2006 Titan SE 4x4 Tow vehicle
2003 350Z Trackcar - RIP Buttonwillow
I used the Periphreal PNXI that is a wiring adapter. It plugs in between the radio harness, and allows you to hook up 2 RCA inputs to your factory radio. I love it, it is simple to install and set up. Sound is a TON better than through the AUX input on the 2004's... Hope this helped.
I installed my XM Commander in the blank where the LE has the multi-info display.
2008 Crew Cab SE Long bed 4x4
Timberline Green Exterior
Almond Interior
Mod's: factory 18" wheels, Toyo Open Country A/T 325/60R18, N-Fab 6-step Nerfbars, Sliding OEM Toolbox, AVS Vent visors, Tint, CUSTOM One-Off JesHand Creations Bumpers, Tailgate bib Cover, color matched steering wheel wrap, Chrome swap on mirrors and door handles, PRG 1.3" Level kit
Yeah, She's the Biggest One
It must be a blessing to some that stupidity isn't painful...
General James Mattis, USMC to Iraqi tribal leaders.
"Allies or enemies. You make the call. I come in peace. I didn't bring artillery. But I'm pleading with you, with tears in my eyes: If you Faq with me, I'll kill you all."
