Old 02-14-2007, 10:17 PM   #1 (permalink)
white_titan05's Avatar
Send a message via AIM to white_titan05
front driver side window...
i have just noticed that it is starting to rattle and squeek when i hit bumps on the road does anyone else have this porblem?
white_titan05 is offline   Reply With Quote
Old 02-20-2007, 01:51 PM   #2 (permalink)
Re: front driver side window...
I had a similar problem but it was actually with my door. I thought it was the window initially but I took my truck in and they adjusted my door so it closed tighter...no more rattle and squeak
trogers is offline   Reply With Quote
Old 03-01-2007, 11:49 PM   #3 (permalink)
Thanks For The Info I Will Have To Chck It Out
Old 03-03-2007, 01:14 PM   #4 (permalink)
Yes it's a few things:
the plastic/hard rubber in the top corner.. it hits against the door metal and clinks
the rubber gaskets all over the place are terrible. try to find some lube that stays and put it on. i siliconed all of them a few days ago and it was dead quiet. now it's rattly again after it dried up.
if you've taken off the door panel, one of the release latch cables might vibrate against the plastic screw channel that goes from the frame and to the inside panel (where you screw it in place).
My TT status expired! Time flies! Please don't thank me in any posts. I never cared for that nonsense and in fact hate it. So dont do it!
gyrate is offline   Reply With Quote
Old 03-06-2007, 10:02 AM   #5 (permalink)
KUSTOMZMAN1's Avatar
thats what we do at the dealer first spray the window runs with a silicon lube and then if it still rattles from there, you may need a new window run.
KUSTOMZMAN1 is offline   Reply With Quote
On windy days air gets though the driver side window. Jeostang Titan General Discussion 39 01-10-2008 09:34 PM
Driver side Window STF Titan General Discussion 10 12-01-2004 01:29 PM
Driver window question Birdman Titan General Discussion 1 11-01-2004 12:20 PM
Driver Side Power Window Issue smoketitan Titan Problems & Dealer Service 8 07-29-2004 10:01 PM
Driver side window is acting funny vw3vr6 Titan Problems & Dealer Service 14 05-10-2004 10:52 AM
