Old 04-16-2007, 08:52 AM   #1 (permalink)
Rear Door Hinge (176 degree)
First of all let me admit to you guyz that I don't own a Titan. But I am currently building a custom wheelchair accessible truck, and I figured you guyz would be knowledgeable with the info I need. In order to get the wheelchair in we bagged the truck, which is done now. Now we need to lower the floor and suicide the rear door so the wheelchair can get inside. So I was wondering, since the Titan has a 176 degree rear suicide door, how much does one of the hinges cost? I've looked at aftermarket suicide hinges and they are between $500-$1000. Any info you guyz have would be very much appreciated. Thank you.
Cody
Low2DaEarth is offline   Reply With Quote
Old 04-18-2007, 03:24 PM   #2 (permalink)
TIsTAN's Avatar
Re: Rear Door Hinge (176 degree)
you should be able to find what you need here,
http://www.trademotion.com/partlocat...=7&catalogid=2
TIsTAN is offline   Reply With Quote
Old 04-18-2007, 04:52 PM   #3 (permalink)
Thanks man, appreciate it.
Old 04-18-2007, 05:23 PM   #4 (permalink)
AgTitan06's Avatar
Check this thread out..This girl has a Titan with a wheelchair setup.
http://www.c l u b titan.org/forums/showthread.php?t=16063
Remove the spaces in c l u b t
Liftgate hinge Stomper4x4 Titan Problems & Dealer Service 29 08-17-2008 08:23 AM
strange gap between rear door and bed bohunter741 Titan General Discussion 7 09-11-2006 03:07 PM
picture of the king cab two-stage hinge???? pistolpete Titan Parts & Accessories 4 01-21-2006 01:01 PM
KC Rear Door Adj MikeL Titan General Discussion 2 08-04-2005 01:28 PM
Rear Door not sealed? Ants05SE Titan General Discussion 1 07-07-2005 08:34 PM
