Speedometer Needle Problem
Ok, so I just finished installing my new stainless gauges that I ordered from JasonB (which I love), but I have a slight problem. I'm able to get all of the needles to line up correctly except for the Speedometer needle. For some reason when I plug the gauges back in, the needles do some type of "flickering/shaking" motion and then the Speedometer gauge rests below zero. I start the truck and it still sits below zero (looks like it would be -5 to -7 MPH). After several attempts in trying to adjust the needle while the truck was shut off, I tried to adjust it while the truck was running. I finally got it to rest at zero, however when I turned the truck off and back on, the needle once again sat below zero. I tried a gauge sweep test and that didn't change anything either. I'd appreciate any type of help.
Thanks guys
2006 Nissan Titan : King Cab
Performance Mods: Banks Monster Exhaust - S&B Intake - 2* Timing Advance - Airaid TBS
Exterior Mods: OEM Fogs - BFG ATs 285/65/18 - Halo Projectors with 8000k HIDS
Interior Mods: Stainless Gauges, 12" Infinity 1230w Mounted in tech12 box (On The Way)
