Old 04-14-2008, 07:09 PM   #1 (permalink)
Power Window Motor Removal and Install
My rear driver's side door window quit working today. After I removed the panel (thanks to a great thread on this forum), I realized the cable on the motor had broken. I ordered a new motor and need to install but can't seem to see anything. I especially need to know how the cable is routed. Does anybody know where I can get a diagram of this? I guess I can take the other door panel off but would prefer not to. If anybody has done this before any insight would be greatly appreciated.
Buzzie8 is offline   Reply With Quote
Old 04-15-2008, 01:56 PM   #2 (permalink)
baseballfanz's Avatar
Re: Power Window Motor Removal and Install
Here's a couple of pages from the manual
power-window-motor-removal-install-window1.jpg  power-window-motor-removal-install-window2.jpg
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 04-16-2008, 11:10 AM   #3 (permalink)
I just changed the drivers door window guide assembly on my cousins Titan about a month ago. The cable on his broke too. He bought a replacement from the dealership and it came with the guides and cables all assembled in one assembly without the motor (about $100.00) . All I had to do was tape the window up ( to keep it from sliding down when I unbolted it from the guide) and remove the four bolt that attached the guide assembly to the door and the whole assembly was able to be removed from the lower hole on the inner door skin. After I got it out I took the motor off and bolted it to the new guide assembly and put it back in the door. It was alot easier than I thought it would be. The whole job took about an hour to do.
2005 Titan KC
CST 4" Spindle Lift
PRG 2.5" Leveling Lift
Go Rhino Step Bars
Banks Monster Exhaust
2 Soundsplinter RL-p15's
Elemental Designs Nine.1
Elemental Designs Nine.2X
Elemental Designs Edi 6500's Components
Alpine IVA-D310 In-Dash DVD
200Amp Iraggi Alternator
Optima Red Top
yzfr1rider is offline   Reply With Quote
titan rear power sliding window new in box cab window morafamily@cox.net Buy/Sell 8 09-01-2007 07:35 AM
Replacing window motor Guiseppe Titan FAQ & Howto Area 2 08-22-2007 11:42 AM
window motor vs. window regulator? Pugsly Titan Problems & Dealer Service 2 05-03-2007 09:31 AM
reflections on power window install.... juma Titan Interior Discussion 4 09-19-2005 05:34 PM
3 Panel Power Slider Solar Glass(Power Rear Window) raskm Titan General Discussion 6 11-21-2004 10:26 AM
