Old 04-26-2008, 08:20 PM   #1 (permalink)
Pantera99's Avatar
Cool Dashboard Squeak
Hi all, just wondering if anyone else has experienced the annoying squeaking coming from what seems to be behind the plastic around the 6 cd changer. I love my Titan, had it since last November. And from day one it squeaks like crazy going over every little bump. If I hold the plastic around the audio controls sometimes it stops, or if I hold the center of the dash where the GPS would go it stops temporarily. Any suggestions???
Pantera99 is offline   Reply With Quote
Old 04-26-2008, 08:56 PM   #2 (permalink)
harrolldean's Avatar
Send a message via MSN to harrolldean
Re: Dashboard Squeak
I'm with ya... I have the same squeeks. I'd love to know of any possible fix as well.
Have a great _______.
harrolldean is offline   Reply With Quote
Old 04-26-2008, 11:10 PM   #3 (permalink)
I have the same problem, but i get the horrible squeaky noise from the plastic piece covering all the gauges. I wish nissan would stop using the cheap plastic.
dazedasp is offline   Reply With Quote
Old 05-06-2008, 02:00 PM   #4 (permalink)
TallTexan's Avatar
Start from the bottom of the cover, under the radio, and gently pry the whole cover off. It comes of pretty easily. Once removed, you will see the areas that are rubbing. I used some electrical tape and small pieces of foam to stop the rubbing. You might want to pop the cover above the radio with the tray. It is glued in the back near the windshield and the glue is very lightly stuck. It sometimes squeeks and stops when you push on the radio plate because that plate puts pressure on it. Pull both covers off and you will be able to fix it pretty easy.
Robert Louis Stevenson
Old 05-10-2008, 12:35 PM   #5 (permalink)
dkeenum2's Avatar
i got the same problem but mine is more of a rattle, it started when i put on my muffler though
dkeenum2 is offline   Reply With Quote
Old 05-15-2008, 08:07 PM   #6 (permalink)
Pantera99's Avatar
Thanks, I'll have to give that a try. It's consistent and persistent, very annoying. Have lots of different thicknesses and durometers of foam and padding where I work. Usually crank the radio loud enough where I can't hear the squeaks but that's ridiculous. Have an '02 Xterra as well, Nissan makes great vehicles but they all have little squeaks and annoying details that have been overlooked.
Old 05-15-2008, 10:16 PM   #7 (permalink)
REV18K's Avatar
Same here with Dazedasp. I spoke with a stealership and they just said it was the fit, changing it wouldn't help.
REV18K is offline   Reply With Quote
Dashboard Cracks kellyj00 Titan General Discussion 25 06-18-2007 06:11 AM
noise from dashboard A-Rod Titan Visual & Audio Discussion 1 11-01-2006 05:22 PM
Dashboard Cover? surfrockman Titan Parts & Accessories 4 08-31-2006 08:19 PM
New brakes work great but...squeak,squeak,squeak PENROSE Titan General Discussion 12 07-06-2005 12:24 PM
Dashboard buzzz radiokid Titan General Discussion 6 07-27-2004 11:57 AM
