Old 01-18-2009, 10:06 PM   #1 (permalink)
Question Is it possible...
To swap out the bucket seats and center console from my SE crew Off Road Big Tow with a bench seat from a similar truck.
I know I may have to modify the gated shifter box.
The issue is this. I love my truck!!!
When I bought it I had 3 children, one wife.
Now I have 4 children, same wife.
I wanted the shifter on the floor, not the column when I bought the truck.
FWIW I did search the forum, I just didn't find the data I wanted.
All intel is appreciated!
Thanks! David
Canteen '05 SE CC 4X4
Off Road Big Tow
zenmedic is offline   Reply With Quote
Old 01-18-2009, 11:11 PM   #2 (permalink)
Re: Is it possible...
If your answer is no...
May I have an explanation please?
Thanks David
Off Road Big Tow
Old 01-18-2009, 11:32 PM   #3 (permalink)
TAFOYA'STITAN's Avatar
i think the floos shifter will be in the way. if not i would switch ya
TAFOYA'STITAN is offline   Reply With Quote
Old 01-18-2009, 11:36 PM   #4 (permalink)
vilim12's Avatar
Its doable, hard, but doable
The floor shifter doesnt actually shift straight in the tranny,
I beleive it senses where you put the handle and it sends a signal to shift the actually tranny
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is offline   Reply With Quote
Old 01-19-2009, 02:41 AM   #5 (permalink)
Fox Delta's Avatar
it could be done but it would be a major PITA - new steering columns too - IMO after all the work and expense you'd be better off just trading trucks (if your loan to value is equal or better)
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
37x13.50/17 Toyo M/Ton Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is offline   Reply With Quote
Old 01-19-2009, 07:18 AM   #6 (permalink)
What???
Off Road Big Tow
Old 01-19-2009, 08:53 PM   #7 (permalink)
chrismnj's Avatar
major PITA
chrismnj is offline   Reply With Quote
Old 01-19-2009, 09:13 PM   #8 (permalink)
4mula1fan's Avatar
^^^ 10-4 on that!^^^
TrainingWheelsWhore™
08 Pro 4X RED ALERT SWB Crew cab, big tow, air box mod, cloth bench seats, N-Fabs, EBC Yellow Stuff brake pads coming soon...Thanks Discount Tire!
Towing a Clipper 1465HST Trail ready pop up.
Grumpy Old Man Club
http://s3.bite-fight.us/c.php?uid=214743
4mula1fan is online now   Reply With Quote
Old 01-19-2009, 10:30 PM   #9 (permalink)
MuskyHunter's Avatar
There is a heavy duty cable housing that follows the right side of the floor console. I am pretty sure this leads to the tranny.
2007 Titan King Cab LE 4x4 : Big Tow: Arctic White : Graphite Leather : Painted Armada Air Dam : Truxedo LowPro Tonneau : Utilitrack Bed Divider : Underseat Storage : BFG Long Trail TA Tour Tires: Bilstein 5100 and Icon Shocks
www.secretlake.net
The Following User Says Thank You to MuskyHunter For This Useful Post:
zenmedic (01-20-2009)
Old 01-21-2009, 08:33 PM   #10 (permalink)
I've had my center console out of my 04 with the captains chairs, there is a heavy duty cable that runs out the cab and down to the tranny, the shifter for the bench seat runs down the dash and out pretty much the same place. The only electronic part of the shifter is the locking solenoid that acts as the safety to keep from shifting out of park without your foot on the break. I'm pretty sure it would be a giant pain in the rear!!
Black 2008.5 SE Crew Cab
-Black, cloth bench seat
-SE Preferred Package
-Underseat storage bin
-Tow Package
-Rail System
Mods:
-Cobra 29 CB Radio, Firestick II Antenna, spring, stakehole mount, and cable. Also home fabricated mount.
-Rechargable Mag Light, also with home fabricated mount under front seat.
-Weathertech floor mats.
-KC HiLites 6' Fog light Kit
-KC HiLites Reverse light Kit, with added wiring to trigger in reverse, cargo lights, and then just off.
-Extang Black Max tonnue Cover
Traded:
Black 2004 LE "Off Road" Crew Cab
-Black Leather
-Tow Package
-Rail system
Mods:
-K&N Air Filter
-Black Max Tonnue Cover
-Mag Light rechargable flashlight
-Auxiliary reverse lights
dv3andrs is offline   Reply With Quote
The Following User Says Thank You to dv3andrs For This Useful Post:
zenmedic (01-24-2009)
