Old 04-06-2009, 10:06 AM   #1 (permalink)
adding power seats?
I am attempting to install power seats from an 06 titan with leather heated seats.
i am stuck, anyone have a wiring diagram or know how to get power to the seats so the motors will work?
n8dawgsmu is offline   Reply With Quote
Old 04-07-2009, 01:34 PM   #2 (permalink)
Just-in's Avatar
Re: adding power seats?
Shoot if the motors are 12v can't you just tap off the battery and ground to a bolt on the seat
Old 04-07-2009, 09:10 PM   #3 (permalink)
This is what i figured out on the drivers side seat:
green wire appears to be the remote/accessory wire (hooked up to ignition or in my case my amplifiers remote wire)
thick white wire is constant (connected to my 12V power source i.e. battery)
black wire is ground
green wire with white stripe is ground (i could have connected these to the seat bolts but i just went ahead and connected them and everthing else to my amplifier power/ground/remote sources
This is what you need to get the motors going driver side. the passenger side is just a power and ground (black is the ground)
(if you are pulling the seats out of a wreck or parts truck cut the factory wiring harnesses well below the connectors so you can still disconnect the seats if need be.. it makes a lot of difference.
---- i will let you know when i figure out the memory seats and heaters.
Old 04-10-2009, 07:59 PM   #4 (permalink)
Just-in's Avatar
If you need pics or anything Let me know.
Power Seats in a none Power seats truck Titan_3nE Titan Interior Discussion 7 06-03-2009 06:10 PM
Adding Power locks to a XE wilsond3010 Titan Interior Discussion 3 02-19-2009 11:49 AM
Need advice on adding power windows/locks tr0uted Titan Interior Discussion 13 04-11-2005 02:14 PM
Adding a power rear window to 2004 SE CC? jdmartin Titan General Discussion 5 01-06-2005 02:41 PM
Adding Power Windows/Locks? bfrance Titan Interior Discussion 7 09-20-2004 04:07 PM
