Old 04-17-2009, 05:58 PM   #1 (permalink)
Where to put amps in Crew Cab
I have a 2004 crew cab and I was wondering where you put your amps? I have a 2000 watt mono amp so its pretty big. Please tell me or post a picture where your are at.
AZTitan2004 is offline   Reply With Quote
Old 04-17-2009, 06:00 PM   #2 (permalink)
MXtitan24's Avatar
Re: Where to put amps in Crew Cab
I have had them under the drivers seat and on the back wall behind the seat. the wall was the best place IMO
MXtitan24 is offline   Reply With Quote
Old 04-17-2009, 07:17 PM   #3 (permalink)
2004 does not have the electric window slider on the backwall so there is alot of room to mount amps.
Audio Install (3 amps, Changer, HU, Matrix, Comps, Subs, PacSWIX, Optima, Sirius)
Old 04-17-2009, 11:06 PM   #4 (permalink)
If you have it under the front seats wont the amps over heat from the ac/heater vents rigjt by the amp. The reason why i dont have it behind the rear seat ia because its to hard to get to if you need to adjuat anything. Do you have a pic of your setup
Old 04-18-2009, 10:35 AM   #5 (permalink)
MXtitan24's Avatar
it's harder to adjust the amp under my seat then on the back wall because you have to pull it out because there is no room to work under there. IMO backwall is the best
Old 04-18-2009, 10:39 AM   #6 (permalink)
Underagedtitan's Avatar
The back wall seems easiest. My 250watt JL monoblock is under the drivers seat and it's pretty small so it works just fine there. But if i had that 2000watt giant it'd go on the back wall.
2004 LE KC BT 4X4 (everything but GPS)
285/60/20 Toyo Open Country AT's
20x9 Ultra Mako's
KOBALT low profile tool box
35% tint w/15% on front
250/1 JL amp W/ 10" JL W3 subwoofer
49$ ebay special!
Many mods to come!
Underagedtitan is offline   Reply With Quote
Old 04-18-2009, 10:41 AM   #7 (permalink)
MXtitan24's Avatar
that 2000 watt one probably wont even fit and if it does it's going to be TIGHT
Old 04-18-2009, 11:07 AM   #8 (permalink)
Hey az wanna post some pics or the brand of amp?
Old 04-18-2009, 10:45 PM   #9 (permalink)
the Brand is Power Acoustik and the model is called BAMF. I dont have any pics yey but heres the website with a pic and the demensions. Its the 2000/1 class d one. Thanks for the help
bamf amp
Old 04-19-2009, 02:15 PM   #10 (permalink)
travelship's Avatar
There is a lot of room in the '04s, just make sure it's not too deep (stick out from the wall), there is tight clearance at the bottom by the seat brackets. This was in my '04.
You can make an amp mounting board pretty easily, here's a link to my install thread.
Travelship's install
04 4X4 LE Crew Cab, Purchased Used 3-06, Sold 3-09
Gone, but not forgotten!
Without Trucks, America Stops
If you got it, a truck brought it.
"Don't waste your breath to save your face, When you have done your best,
And even more is asked of you, Fate will decide the rest" --The Grateful Dead
"I've seen too much not to stay in touch with the world made of love and luck,
I've got a big suspicion about ammunition, I never forget to duck" --Jimmy Buffett
travelship is offline   Reply With Quote
Old 04-19-2009, 06:56 PM   #11 (permalink)
thanks that looks really good!
Old 04-20-2009, 01:15 AM   #12 (permalink)
o town rider's Avatar
Very clean i
2007 SMOKE CREW CAB
EXTERIOR:
COLOR MATCHED AIR DAM
22" KMC CHROME ROCKSTARS
FALKEN ZIEX 305-45-22
RECON LINE OF FIRE
6000K HID'S
PERFORMANCE:
UPREV TUNED
INJEN COLD AIR INTAKE
2* TIMING ADVANCE
JBA CATBACK EXHAUST
AUDIO/VISUAL:
CDT COMPONENTS
CDT -69CX FRONTS
CDT CL-6.25 REAR
o town rider is offline   Reply With Quote
Old 04-20-2009, 01:16 AM   #13 (permalink)
Very clean install... I'm impressed!! Good job.
2007 SMOKE CREW CAB
EXTERIOR:
RECON LINE OF FIRE
6000K HID'S
PERFORMANCE:
UPREV TUNED
2* TIMING ADVANCE
JBA CATBACK EXHAUST
AUDIO/VISUAL:
CDT COMPONENTS
CDT -69CX FRONTS
CDT CL-6.25 REAR
Old 04-20-2009, 01:23 AM   #14 (permalink)
travelship's Avatar
Thanks, I figured you new guys probable hadn't seen my install. By the way, this JL 500/5 and a set of Image Dynamics CXS64 Chameleons are for sale.
Audio Stuff F/S-JL Audio, Image Dynamics, Sundown
rear seat room king cab vs crew cab bucketfan Titan General Discussion 13 11-08-2008 04:57 PM
Contoured King Cab & Crew Cab Enclosures tech12volt Titan Visual & Audio Discussion 77 09-11-2007 07:06 PM
08 Titan Xe Crew Cab And King Cab Long Bed Got Here Today KUSTOMZMAN1 Titan Pictures & Media Post 40 05-10-2007 09:05 PM
tapping rear speakers fo crew cab to put amp and sub... titanic_081806 Titan Visual & Audio Discussion 6 09-15-2006 09:02 PM
Can you mount Crew Cab Factory Steps on a King Cab itrice Titan Parts & Accessories 3 06-14-2005 03:09 PM
