Old 04-22-2009, 08:17 PM   #1 (permalink)
replacing center dash speaker
does anyone know how to remove the cover over the center speaker in the dash? I have been able to remove the face plate and radio but confused about the cover over the speaker. Thanks
fletcherjk is offline   Reply With Quote
Old 04-22-2009, 09:26 PM   #2 (permalink)
Yellomantis's Avatar
Re: replacing center dash speaker
I would also like to know this. I want to wire my CB radio to that speaker.
2006 4X4 LE OR CST 7" Lift, RadFlo 2.5 coilovers, PRG Uppers, RadFlo 2.0 rears, Deaver 2.5 mini pack, 3" custom block, PRG traction bars, TC HD rear shackles, 2* advance, Custom Supertrapp exhaust, XE mirror covers and door handles, 17X8 AR Mojave Teflon's, 35/12.50R17 Toyo Mud Terrains, Bushwacker fender flares.
www.myspace.com/yellomantis
Old 04-22-2009, 10:45 PM   #3 (permalink)
First do you have the 2 wheel drive or the 4 wheel drive? If so i dont think matters. To get the cover off you must pull on it and it should come off. Did you try that one.
anthropod929 is offline   Reply With Quote
replacing factory speaker ? leukus Titan Visual & Audio Discussion 1 02-04-2007 11:35 PM
Replacing center channel speaker grunge311 Titan Visual & Audio Discussion 2 09-28-2005 06:00 PM
center speaker --how do you get to it? smoketitan Titan Visual & Audio Discussion 4 06-02-2005 01:35 AM
adding a center speaker... hunka27 Titan Visual & Audio Discussion 0 05-30-2005 01:41 AM
Replacing center bench with a custom subwoofer box! Chris M. Titan Interior Discussion 21 03-13-2005 02:13 PM
