Old 05-11-2009, 07:12 AM   #16 (permalink)
Re: Interior smells horrible, HELP!
Yeah, I think getting rid of the smell is only part of the problem. You need to figure out where the moisture is coming from otherwise, you're in a losing battle.
The AC drain plug was a common problem and easy fix.
Good luck!
2004 Chevy RCSB 5.3/4.10/Auto/Wheately Tune/True Trac/ Intake/Exhaust /e-fans/ 2" Drop Shackles out Back and Titan Rims all around!
SOLD**2004 SE CC Radiant Silver 4X4 w/ Pop. Pkg and DVD**SOLD
SOLD **2005 Titan XE KC w/ Preferred Package BLACK **SOLD
buzzkillwill is offline   Reply With Quote
Old 05-11-2009, 07:15 AM   #17 (permalink)
Banned
I too have the same problem every year. Unfortantly today suppost to be mid 70s low 80s and mid 80s tomorrow. So A/C is in my forcast. So what I do for about a week is I turn the A/C on, all the windows down and it naturally does its thing. After a week or so, smell is gone, and windows go back up.
We're telling you, it's the A/C system. ..yours just may be worse off than others. Try it and get back to us
adamdude04 is offline   Reply With Quote
Old 05-11-2009, 07:22 AM   #18 (permalink)
Well i pulled back the carpet on the drivers and passenger side and the insulation was damp, which led me to using the dehumidifer. I actually stuck a leaf blower in between the carpet and let it go for a while. As far as the AC problem, there was no water standing in the floorboard, and when I first bought the vehicle I took it to the nissan dealer with a gas gauge issue and there was a note on the invoice that said "condenser check OK". Is this the common AC problem? I'm not sure. I think the first dealer used a powerwasher to clean the front carpets. The backseat insulation is not wet.
TN Titan 09 is offline   Reply With Quote
Old 05-11-2009, 07:30 AM   #19 (permalink)
gary748's Avatar
TN Titan, check out the link below regarding the AC drain issue. You're probably going to have to remove the carpet and give it a really thorough cleaning to get rid of the mold smell. If it's still under the 3/36 warranty take it to the dealer and let them replace the carpet and padding...
passenger side floor mat wett............... - Nissan Titan Forum: Club Titan Forums
IRC VK56 PIT CREW CHEIF
2005 Silver SE 4X2 KC
Performance: Uprev Tuned, Injen CAI (Wrinkle Black Powder coated), '07 Intake Manifold, Nismo Exhaust,
TrueTrac, Mag-Hytec
Suspension: Stillen Rear Sway Bar, PRG Shackles
Wheels: 22" Foose DF-6(Black), Yokohama Prada-X tires
Exterior: Armada Front Air Dam, Catz 6k HIDS, DDM 6k fogs
Audio: JL Audio, Alpine
gary748 is offline   Reply With Quote
Old 05-12-2009, 11:00 AM   #20 (permalink)
Update. There was no water standing in passenger floorboard. The drivers side insulation was equally damp. Idiot from the rinky dink dealer probably powerwashed the front floorboards. I bought 2 yards of insulation, pulled my front seats out, pulled the old insulation out, put a fan on it for a while, sprayed the floorboard with clearcoat spraypaint to kill the odor, cut the new insulation and put the titan back together. Now I wait... The old padding smelled horrible, it had to have been the problem. I checked the rest of the padding in the rear and it was dry...pray for me.
Old 05-12-2009, 12:12 PM   #21 (permalink)
MacOtac's Avatar
Send a message via MSN to MacOtac Send a message via Yahoo to MacOtac
Quit doing this in it!!!!!! LOL
Sig: By dOva
"Green Machine"
2005 SE CC 2WD Canteen Green
MacOtac is offline   Reply With Quote
Old 05-12-2009, 07:50 PM   #22 (permalink)
Smell is gone. Smell of 3M adhesive lingers, but better than musty ***. The cheap way ended up being the most effective way. It was just a little labor intensive.
Old 05-12-2009, 09:13 PM   #23 (permalink)
redneckpapa1996's Avatar
I got the smell you describe and it is coming from inside the door panels and the smell is worse in the summer and when the windows are first rolled down...No damp or wet carpet or nasty vent smell in my truck...
I have posted this many times and no one else seems to have the same issue or they are scared to let the windows down and smell the groove where the window goes into the door..
Try that..
I am for real!
..................................BEERWHORE.................................
"THIS TRUCK IS AWESOME" !!!........"Uncle Sams Misguided Children"
Marine Corps is a department of the Navy...>"THE MENS DEPARTMENT"!!!
2004-LE-CC-BT-OR-4X4-w/VDC-Utilitrac-Pearl White---94,000 miles and still going strong!!!....."THE BIG TWUCK"!!!
2* advance, Volant gen.III CAI, TBS, Custom Flowmaster 40 exhaust w/4" duel tips, Bilstein 5100's, Weathertech floormats, Okole seat covers, Westin Bullbar w/KC Lights, Michelin LTX-AT2, Seres tail lights
redneckpapa1996 is offline   Reply With Quote
Old 05-12-2009, 10:54 PM   #24 (permalink)
chunko's Avatar
Yeah every once in a while I leave a bucket of dri z air in my vehicles to pull the moisture out. It helps prevent/treat this issue.
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore
"What if we picked the wrong religion? Every week we're just making God madder and madder." - Homer Simpson
chunko is offline   Reply With Quote
Old 05-12-2009, 10:56 PM   #25 (permalink)
chunko's Avatar
Try that..
I am for real!
I puked out of my truck window and some got in there... marinated and smelled like death.
Smell is gone now...
You might want to try spraying some lysol in there...
2005 CC 4x4 SE
AKA
Old 10-09-2009, 01:10 PM   #26 (permalink)
Well its been 4 months and now the water is back. I should have listened and took it to the dealer. It was the AC drain. They fixed it per TSB and are replacing all the carpet.
Old 10-29-2009, 10:20 PM   #27 (permalink)
Could be giving the car to a smelly valet attendant (Sienfeld episode).
grpape is offline   Reply With Quote
Old 11-12-2009, 09:26 PM   #28 (permalink)
My 2004 Titan is ruined from A/C leak that Dealer was unable to fix. Now it is full of Toxic Mold.
waterlogged is offline   Reply With Quote
New Altima's heater smells wierd joeinstl Off-Topic Discussion 7 05-12-2008 07:42 AM
A/C smells sour Mike P Titan Problems & Dealer Service 14 06-01-2007 04:15 PM
Exhaust smells like Amonia Ramon Titan General Discussion 10 05-30-2006 07:20 PM
oil smells like fuel? GreenT Titan Engine, Transmission & Drivetrain 1 11-12-2005 09:38 AM
Engine oil smells like gas.... maestro Titan General Discussion 11 01-03-2005 06:00 PM
