Old 05-06-2009, 08:10 AM   #1 (permalink)
Interior smells horrible, HELP!
I recently bought an 06 titan and the interior smells horrible. Smells musty. I can't seem to find the source. I have smelled everywhere in the truck and can't pinpoint the source. I have opened up a odor absorbing disc, sprinkled baking soda, sprayed odor eliminator, aired out the vehicle, vaccumed it out and the carpet and upholstery was cleaned before I bought it. It has been raining for several days and there is no sign of moisture anywhere. I'm out of ideas, anyone got any ideas? Thanks in advance!
TN Titan 09 is offline   Reply With Quote
Old 05-06-2009, 08:16 AM   #2 (permalink)
Just-in's Avatar
Re: Interior smells horrible, HELP!
might be in the dutcwork... cabin airfilters?
Old 05-06-2009, 08:16 AM   #3 (permalink)
Blackbeauty's Avatar
It's most likely in the vents.... Residual moisture from the condensor can accumulate and cause mold and mildew in the intake vents... There are some spray cleaners to rid the vents of the mold, but you'll probably need an air purifier/Ionizer like this to get the smell out afterwards:
UV Air Purifiers Ionic Electronic Air Cleaners UV Ionizers Ozone Generator HEPA Systems Home Air Cleaner Purifier Filters
Old 05-06-2009, 08:18 AM   #4 (permalink)
Carbeaux's Avatar
Could be one of the ones that had the AC drain not working properly, therefore dumping that moisture on the pasenger floorboard. Even if it's not wet now, just high humidity could be making it smell.
Hook 'Em Horns!
Carbeaux is online now   Reply With Quote
Old 05-06-2009, 08:19 AM   #5 (permalink)
I didn't notice any odors when smelling the vents and I smelled around the cabin filter and it didn't seem to have an odor either. Maybe in the duct work and just can't smell it directly?
Old 05-06-2009, 08:23 AM   #6 (permalink)
Carbeaux's Avatar
Mine gets a mildew smell if it sits for a while. Then when I get back in it and turn the AC on, that's when I smell it. I don't smell it right when I get in, only when the AC is on. After a few days of daily driving the truck again, it goes away.
Hook 'Em Horns!
Old 05-06-2009, 08:23 AM   #7 (permalink)
Usually only smells when the A/C or heat is turned on....
Old 05-06-2009, 08:25 AM   #8 (permalink)
This smell lingers all the time. As soon as i open the door I can smell it. I think it actually helps to turn the air on, kind of muffles the stinch.
Old 05-06-2009, 08:26 AM   #9 (permalink)
Air Ionizer... Period....
Old 05-06-2009, 08:29 AM   #10 (permalink)
check the padding under the front passenger side carpet
The Following User Says Thank You to bestatchess For This Useful Post:
Carbeaux (05-06-2009)
Old 05-06-2009, 08:32 AM   #11 (permalink)
Irish125's Avatar
Coffee grinds can work to absorb and eliminate odors as well. You could even choose a flavor of choice. I have used them before to remove the vomit smell from my ex's brand new car when she decided to lean in and not out.
'08.5 SE KC
Irish125 is offline   Reply With Quote
Old 05-06-2009, 08:34 AM   #12 (permalink)
Will do. Thanks guys.
Old 05-06-2009, 08:47 AM   #13 (permalink)
I had a Chevy a few years ago that did the same thing. The dealer told me to run the heater through all the vents for about 10 minutes. That fixed my problems.
MikeG is offline   Reply With Quote
Old 05-11-2009, 06:39 AM   #14 (permalink)
To update this thread, I tried the coffee grounds. It covered it up but ultimately made it stink worse. I decided to have truck professionally detailed, inside and out. The truck looked great when it was done. But...still had a small hint of funky odor. I hooked up a dehumidifer in the truck and let it run for several hours. it pulled out about 2 cups of water and since has smelled much better. The smell now is of the cheap shampoo the original dealer used to clean it out. Now I am trying to get rid of it. The dehumidifer worked wonders though. It was actually my wifes idea After I get rid of the rest of the smell I will update. I found a solution called Force Out on the internet, claims to get rid of any odor. Wonder if it works?
Old 05-11-2009, 07:09 AM   #15 (permalink)
BobNYC's Avatar
I'd still check the A/C drain if you haven't already. That is a common problem and can lead to the musty smell.
'07 SE KC Titan, Tow, Utility Bed, Off Road and Preferred packages, Majestic Blue, rear diffy replaced at 30k miles
BobNYC is offline   Reply With Quote
New Altima's heater smells wierd joeinstl Off-Topic Discussion 7 05-12-2008 07:42 AM
A/C smells sour Mike P Titan Problems & Dealer Service 14 06-01-2007 04:15 PM
Exhaust smells like Amonia Ramon Titan General Discussion 10 05-30-2006 07:20 PM
oil smells like fuel? GreenT Titan Engine, Transmission & Drivetrain 1 11-12-2005 09:38 AM
Engine oil smells like gas.... maestro Titan General Discussion 11 01-03-2005 06:00 PM
