Old 05-29-2009, 12:14 PM   #1 (permalink)
Power Window wont roll up
My 04 Titan started having some issues with the Drivers Side power window. It usually rolls completely up or down, but when I only roll the window down half way it gets stuck and wont move up or down. I have to push it down with my hands and then it catches and starts to roll down and then will roll all the way up. This problem only happens when I roll the window down half way. Any thoughts?
shiftmx731 is offline   Reply With Quote
Old 05-29-2009, 12:17 PM   #2 (permalink)
salstats's Avatar
Talking Re: Power Window wont roll up
you need to replace the motors on your two front windows. these problems accures to all the 2004 Nissan titans. also in some occasions to the 2005.
salstats is offline   Reply With Quote
Old 05-29-2009, 01:15 PM   #3 (permalink)
Is this something I can do myself? How much does it cost for the motors?
Old 05-29-2009, 01:24 PM   #4 (permalink)
54warrior's Avatar
I don't think that it's the motors. It could be, but it sounds familiar to the problem I had, which was jammed up/busted/broken cables inside the door, which attach to the spool on the motor. Cost me $120 to fix. new cable/guide/spool. All which mounted onto the motor.
You could remove the motor and see if it's working w/o the spool attached.
2005 Nissan Titan CC SE 4x4
Old 05-29-2009, 01:24 PM   #5 (permalink)
54warrior's Avatar
Oh and BTW... you really won't know which problem it is (motor vs. broken cable/etc.) until you take the whole thing apart anyways. Dive in!
who want the window roll up mod?? salstats South Western Forum 60 05-28-2009 02:17 PM
titan rear power sliding window new in box cab window morafamily@cox.net Buy/Sell 8 09-01-2007 07:35 AM
Security Window roll down??? burntfox Titan General Discussion 14 11-07-2005 06:41 PM
window roll down w/ remote mytitan Titan General Discussion 2 08-15-2005 08:19 PM
remote window roll down mlvswoll Titan General Discussion 5 07-25-2004 10:11 PM
