Old 06-07-2009, 08:09 PM   #1 (permalink)
MXtitan24's Avatar
Fire Extinguisher Inside
after seeing a car fire on the freeway I decided to step it up haha
MXtitan24 is offline   Reply With Quote
Old 06-07-2009, 09:02 PM   #2 (permalink)
TitanBlue's Avatar
Re: Fire Extinguisher Inside
I did same, except I mounted it to the hump right behind, just pushes it tighter to the seat. I have a 2 D Cell Mag Light in front of the Passenger Seat in similar fashion.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Old 06-07-2009, 09:28 PM   #3 (permalink)
HRTKD's Avatar
I have a slightly larger fire extinguisher that I keep in the underseat storage bin. I have had to use a fire extinguisher to put out an engine fire (not in my car though) so I know first hand how well they come in handy. I tried mounting it to the Utilitrak side rails using QuickFist clamps but could never get it good enough to trust it. So the fire extinguisher sits in the storage bin.
Jim
Old 06-16-2009, 12:46 PM   #4 (permalink)
I'm more interested in the money in your door. Can I have it?
2006 Nissan Titan XE C/C - Granite, XE Preferred Pkg, Flowmaster SI/DO Muffler, 2* advance, 2.5" PRG Spacer, Pro-Comp ES9000 rear shocks, chrome door handles.
2008 Carson FL162 Fun Runner Toyhauler
PSNissanFleetMgr is offline   Reply With Quote
The Following User Says Thank You to PSNissanFleetMgr For This Useful Post:
DeadRiver (06-16-2009)
Old 06-16-2009, 12:53 PM   #5 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
great idea...... after messing with some wiring in the truck I think it's a safe bet to keep one of these in the cab.
i was just thinking about doing this the other day.... although with such a small unit (that's what she said) you better hope for a small fire.
2004 Sedona Titan LE CC 4wd
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
The Urinator™
DeadRiver is offline   Reply With Quote
Old 06-16-2009, 12:58 PM   #6 (permalink)
etalian2005's Avatar
Send a message via AIM to etalian2005
A small unit's better than no unit.
ESCORT SOLO S2 RADAR DETECTOR FOR SALE!!!
2008 PRO-4X Black on Black 4x4 w/ Leather package, Big Tow, and Utility Bed
BlackJack
Mods:
Performance: Superchips FlashPaq - 93 tune, 18" Magnaflow Muffler
Suspension: PRG 1.5" Leveling Kit
Wheels & Tires: 20x9 Ballistic Offroad Jesters, 33x12.50x20 Toyo Open Country M/T
Audio: 2 12" RE Audio SE's, Sundown SAE-1000D amp, Tech12Volt Sealed Box
Accessories: 6000K McCulloch HID Lows, 6000K DDM Tuning HID Fogs, 20% front tint, 5% in the back, and 5% on top of windshield, Hardwired Valentine 1, RBP 4.5" Black Exhaust Tip
etalian2005 is offline   Reply With Quote
The Following User Says Thank You to etalian2005 For This Useful Post:
DeadRiver (06-17-2009)
Old 06-16-2009, 12:58 PM   #7 (permalink)
54warrior's Avatar
Not where I'd mount it, but good idea none the less.
2005 Nissan Titan CC SE 4x4
Old 06-16-2009, 01:07 PM   #8 (permalink)
Anybody have any other ideas on location mounts? I'm not a big fan of that one.
BlackJack
Mods:
Old 06-16-2009, 06:33 PM   #9 (permalink)
TitanBlue's Avatar
Under the rear seat if no Tech12volt box there! Room for a 3A40BC if you like.
Old 06-16-2009, 07:06 PM   #10 (permalink)
TitanBlue's Avatar
On the floor, it is less likely to become a projectile or hard surface for secondary impact in an accident. Close to the seat, it does not interfere with entry. It must be very secure. A metal bracket is far preferable to a plastic strap.
Old 06-16-2009, 07:10 PM   #11 (permalink)
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
Mine is loose in the center storage area ..
***Dynod before headers @ 272hp 334tq***
*2004 Galaxy Black SE CC
*Rockford Fosgate Punch 200 a4
*One 10" Kicker Comp down firing
*Omega MAX-E Remote Start/Alarm with pager remote
*ECO Systems Fuel Enhancer
*Volant PowerCore CAI / Ram Air Scoop
*AIRE TBS
*2 Degree Timing advance
*Doug Thorley LT Tri Y's
*Used to have AT3030XL muffler / 3" exhaust piping from MF "Y" back ... Now back to stock exhaust
*Magnaflo HF CATS #94165
*Hoppy EasyLift Tailgate Lift Torsion Bar
*Black Alteza style tail lights
*Lund S.S. bug deflector
*NCD 2" Leveling Kit W/ Bump Stops
*Ikon shocks with 1" block in the rear and Bilsein 5100's in the front ( adjusted to middle notch)
*Nitto Terra Grapplers LT285/65R18E1
*Chrome Range Rover Fender Vents
import2nr is online now   Reply With Quote
Old 06-16-2009, 08:15 PM   #12 (permalink)
vilim12's Avatar
Mines a small one behind by the jack in the rear.
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is offline   Reply With Quote
Old 06-17-2009, 08:31 AM   #13 (permalink)
If you have a bed cover, you can mount it in the bed. I attached mine to the underside of my bed extender bracket, which leaves it right by the tailgate for easy access.
If my truck is on fire, I don't want to stay in the cab trying to get the extinguisher.
bu_bear_sh99 is offline   Reply With Quote
Old 06-17-2009, 09:11 AM   #14 (permalink)
I have a Tech box and no room behind my rear seat and no room underneath my driver or passenger front seats. Any other options?
BlackJack
Mods:
Old 06-17-2009, 09:20 AM   #15 (permalink)
DeadRiver's Avatar
one member mounted his on the A pillar on the drivers side.... wish i could find the pics
The Urinator™
Fire Extinguisher anyone? contenderv07 Off-Topic Discussion 4 06-02-2009 08:14 PM
recon line of fire or fire and ice LED light bar? titaninak Titan Performance Modifications 9 05-13-2007 01:17 AM
Katy, TX Fire AgTitan06 Off-Topic Discussion 4 01-13-2007 09:35 PM
Fire extinguisher mount Urban_Redneck Titan General Discussion 13 08-07-2005 06:29 PM
Fire direction SickWhip Titan Interior Discussion 3 02-01-2005 08:59 AM
