Old 07-11-2009, 11:47 AM   #1 (permalink)
Driver side door switch king cab
06 SE 4x4. Can anyone tell me the location of the driver side door switch on the king cab? The interior lights are coming on while driving. When i pull on the door they shut off, so something needs to be lubed or adjusted. I can see several switches in the door jam on the third door, but i'm sure that those arn't related. Is it on the slide are that opens and shuts with the door?
rcowboy is offline   Reply With Quote
Old 07-11-2009, 02:11 PM   #2 (permalink)
Re: Driver side door switch king cab
Okay, for anyone that might have the same issue, I solved the problem. The striker on the lower portion of the third door was really loose. I could move it around an inch in either direction. A t-40 torx solved the problem by putting the striker back in position and tighting the torx bolts. I would of thought that nissan might of put alittle thread lock on these, but I guess not. Hopfully this solves my water leaking issue too. I've also had a lock / latch issue with the tail gate too.
Rattle from drivers side door on a king cab... CRStewTAMU Titan General Discussion 10 09-30-2008 08:12 PM
No Up Power with Rear Side Windows from Driver Switch gkoyle Titan Problems & Dealer Service 11 07-23-2008 08:58 PM
Driver side cab door seal wear johnszcz Titan Problems & Dealer Service 2 09-19-2007 07:11 PM
how do you remove the drivers side king cab door panel? titanmike Titan General Discussion 0 05-20-2006 01:00 PM
Rattle in driver side door or dash Stomper4x4 Titan General Discussion 0 03-28-2006 07:45 AM
