Old 09-16-2009, 08:02 PM   #1 (permalink)
Fly boy's Avatar
Send a message via AIM to Fly boy
streaks on tint
So I have nasty streaks on my window tint on both driver and passenger side. I called the Stealership up here in Cheyenne and they say that if it is from factory it should be covered in my 5 year interior warrenty.
I talk to a local tint guy and he said it was because of the velvet/fuzzy strip that "clear's" the window when it goes down.
I am taking in to the shop tomorrow to see if that is true. I will let you know how it goes.
2006 Red Alert LE Crew Cab
Mods now: Visor CD holder, Extang Sabor Tonneau, Drop in Amsoil with DIY intake, 2* timing advance (WORTH IT!), 10" W3v3, Bully Dog PP, popped resonators
Mods soon: Black powder coated rims, CAI
Fly boy is offline   Reply With Quote
Old 09-16-2009, 08:10 PM   #2 (permalink)
vilim12's Avatar
Re: streaks on tint
If your weather strip on the windows plastic or a soft velvet felt type material?
If its plastic its most likely scratches from it
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is offline   Reply With Quote
Old 09-16-2009, 09:06 PM   #3 (permalink)
Fly boy's Avatar
Re: streaks on tint
Velvet was the word I was looking for. the interior warrenty should cover it the guy said, as long as the tint was stock.
Old 09-16-2009, 09:24 PM   #4 (permalink)
vilim12's Avatar
Re: streaks on tint
Your talking about the rear windows then right? Yea im guessing it should cover it, is your strip velvet or a hard plastic?
Crew Cab Long Bed
Old 09-17-2009, 02:06 AM   #5 (permalink)
Just-in's Avatar
Re: streaks on tint
the rear windows shouldn't scratch, the tint isn't a film it's colored glass... do you live in a dusty area? if so and the scraper seal is dirty hanging onto sand and scratching the glass hopefully they will but probably won't cover it by warranty.
I've enver heard of a T coming from the factory with the fronts tinted. if the dealer did it and did apply velvet to the scraper seals if you didn't have it from the factory and it scratched under normal wear and tear, and isn't dirty they should help you out. At very least a deal on re-tinting.
you may be able to rub the scratches out of the film with some plasticX or another plastic polish/headlight restorer.
Good luck.
Old 09-17-2009, 12:47 PM   #6 (permalink)
Re: streaks on tint
i have the same issue i live in the az dusty area. ive had the issue since about 8k on the odometer. never got an answer from the dealer
selling my paintball guns look here--->http://www.titantalk.com/forums/buy-...ml#post1853074
2007 SE radiant silver 4x2
22x9.5 AR Marins
kumho 305/40/22 ecsta
10k hid conversion (****for sale*****)
2* advance
k&n gen II FIPK
Mcgauhys 2/3 lowering kit
superchips tuned
jba exhaust
armada front airdam
SOON:
JWT cams when they come out
Detroit Truetrac LSD
JBA headers with magnaflow high flow cats
UPREV when headers or JWT come
painted front hood cowl
hellwig rear anti-roll sway kit
upgraded front and rear brakes
rgb133 is offline   Reply With Quote
Old 09-17-2009, 01:33 PM   #7 (permalink)
TXSRedTitan's Avatar
Exclamation Re: streaks on tint
I have the same issue on my 06 and it has done it since i picked it up new. The dealer had installed tint on my front windows and the king cab windows have the dark privacy glass. But yeah my driver side has like 3 sections getting thin vertical scratches from about the top edge to the about a 1/4 of the way down from putting the window down to get to the ATM. The dealer gave some story about it being wear and tear. Pure BS of course. I took the door panel off and took the stripping pieces off and cleaned them along with taking a crescent wrench and pinching the doors top inner pinch seams where one of the inner strips mounts and slightly bent them away from the inner glass so they dont have too much pressure on the glass. It fixed some of them but i see a section i missed, that i need to go back and fix. I had the windows re-tinted and then saw the scratches coming back in the top 1/4 and not the whole length of the window. now i have to get them re-tinted again. Im told by the tint shops they have some kind of mole skin type stuff they can put on it to fix the issue but its like $35. i will go to Wal Mart and buy some from the foot area near the pharmacy and buy some for less if thats the case. LOL Anyway that what i have found out from my exp.
2006 TItan SE 2wd KC Red Alert, K&N, Little Tow Package, Tint, 20" LE Titan Rims (installed 8/21), Cooper Zeon LTZ tires 275/60/20 (installed 8/21), PRG Radflo front Coil Overs, Bilistein 5100 series rear shocks (Purchased / Installed), Banks CAI, Banks Monster Exhaust. (Purchased 9/19 Installed 10/4) Audio
Then more to come! TruTrac, Cortex, etc.
TXSRedTitan is offline   Reply With Quote
Old 09-17-2009, 01:47 PM   #8 (permalink)
EDDIE FONZARELI's Avatar
Re: streaks on tint
if you tint your windows, fronts or rears you NEED the FELT strip or you windows will (or might not) streak. felt usually runs $20 extra per window because they have to pull the door panel slightly open to install the felt.
eDDie FonZareli
2005 SE 2wd
6" Procomp Stage 2 Suspension with a 4" Rear Block
3" Body Lift
CST CBDB
AFE Stage 2 CAI with BD 2* Timing Advance
3.00 in/out Bullet Muffler, Dumped
Custom 2.50 to 3.00 Exhaust Piping
37" Toyo Open Country M/T's
20x10 XD Rockstars
Smoked tails, Headlight Mod & Grille
2 10" Kickers, Kenwood Excelon Double Din
Powered by Fosgate
WHATS NEXT
PRG UCA'S
Coil Bucket Spacer
Deaver C10 Leaf Pack
Traction Bars
EDDIE FONZARELI is offline   Reply With Quote
The Following User Says Thank You to EDDIE FONZARELI For This Useful Post:
Just-in (09-17-2009)
Old 09-17-2009, 02:20 PM   #9 (permalink)
Just-in's Avatar
Re: streaks on tint
Originally Posted by TXSRedTitan View Post
I have the same issue on my 06 and it has done it since i picked it up new. The dealer had installed tint on my front windows and the king cab windows have the dark privacy glass. But yeah my driver side has like 3 sections getting thin vertical scrathes from about the top edge to the about a 1/4 of the way down from putting the window down to get to the ATM. The dealer gave some story about it being wear and tear. Pure BS of course. I took the door panel off and took the stripping pieces off and cleaned them along with taking a crescent wrench and pinching the doors top inner pinch seams where one of the inner strips mounts and slightly bent them away from the inner glass so they dont have too much pressure on the glass. It fixed some of them but i see a section i missed, that i need to go back and fix. I had the windows re-tinted and then saw the scratches coming back in the top 1/4 and not the whole length of the window. now i have to get them re-tinted again. Im told by the tint shops they have some kind of mole skin type stuff they can put on it to fix the issue but its like $35. i will go to Wal Mart and buy some from the foot area near the pharmacy and buy some for less if thats the case. LOL Anyway that what i have found out from my exp.
It's not bs if you don't have moleskin or felt on your scraper seals and don't keep it clean the film will scratch. 35.00 is a little high but I paid the extra 20 like fonzy mentionied.
Old 09-17-2009, 02:24 PM   #10 (permalink)
vilim12's Avatar
Re: streaks on tint
I think the 08 models started coming with a felt strip from factory, atleast mine did
Crew Cab Long Bed
Old 09-17-2009, 02:40 PM   #11 (permalink)
Fly boy's Avatar
Re: streaks on tint
Welp took it to the stealership and they said it was just that seal getting dusty, so they WILL NOT cover it. So I am either going to have to live with it, or talk to someone about getting some new tint.
If I get tint, I will be opting for the velvet strip if they offer it.
Thanks all for the imput.
Old 09-19-2009, 12:41 AM   #12 (permalink)
Lightbulb Re: streaks on tint
LOL what i was saying thats BS is that the dealer wouldnt fix it even though i pointed it out to them 3 weeks later when i had to stop in to get a piece that was missing frominside my truck. My truck has the felt piece inside. Has one plastic piece attached to the actual door panel and the felt strip piece along the seam section where the inner door edge is next to the glass. Anyway, i really could find anything on the felt but the piece were really tight against the glass. The inside of my truck pretty clean and still looks brand new. Gets washed and wiped down on the inside almost every week or so since i bought it. I dont drive with the windows down either to keep dirt and dust out of it. But i know what you guys are saying.
Yeah a few of the tint shops down here near Houston told me $35 ea door for the mole skin / felt and the other told me $65ea plus the cost of tinting!! LOL Sheesh.
Thanks Fonzerelli, I gotcha bud. My felt was compressed from it being so tight against the glass. Dealership installed the tint before i purchase the truck, would have thought they would have made sure it was all good to go before selling it.
Old 09-19-2009, 01:18 AM   #13 (permalink)
gweasel77's Avatar
Re: streaks on tint
I've been thinking about getting my ft window's tinted, but i already get those vertical streak's in both my window's from them just going up & down. Look's lik i'll be taking the door panel's off & adding some felt strip's before i go & spend the money for tint. Just to have it get all scratched up within the 1st couple months.
2005 NISSAN TITAN SE KC
IRC VK56 TEAM MEMBER
performance:
UP/REV CUSTOM TUNED
Custom 4" Ram Air / Fujita Intake w/ DEI Heat Shielded Box / AirRaid TBS / TB Screen Removed / TB Coolant Bypass / '08 Intake Manifold / Trans. Cooler / Nismo LT Header's / Banks Monster Exhaust / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding System / Burn-Out Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140
exterior:
Ruff Racing R286 22"x9.5" Chrome's w/ 305/45/R22 Nexen Roadian HP's / Stillen Diff. Cover / Traction Springs / DDM 8K HID's / Armada Air Dam / SolarGard Tint / Tow Hook's / Debadged
Fog Light's w/ HID's Next
waiting on ST Shackles
gweasel77 is offline   Reply With Quote
Old 09-19-2009, 01:33 AM   #14 (permalink)
Just-in's Avatar
Re: streaks on tint
yeah theres places that sell it online just have the tint shop do it though I havn't had any problems.
My old VW had scratches in it cause the strip wasn't clean.
keep your **** clean lol
The Following User Says Thank You to Just-in For This Useful Post:
gweasel77 (09-19-2009)
Old 11-18-2009, 08:25 AM   #15 (permalink)
Re: streaks on tint
my husband tinted my car with precut tint from www.northerntint.com and they have tools you can buy so you wont have streaks and it realy helps. theyre also pretty cheap
chelsie is offline   Reply With Quote
Cleaning black streaks off your camper nnak58 Titan Towing & Hauling 4 11-23-2008 02:56 PM
How do you stop streaks on black paint? njgsx96 Detailing & Truck Care 36 03-25-2008 10:49 PM
Have some light tan colored streaks in oil change today... Omega Supreme Titan Problems & Dealer Service 1 01-19-2008 07:24 PM
tint vu007 Buy/Sell 14 09-23-2005 11:48 AM
