Old 09-22-2009, 07:20 AM   #1 (permalink)
Need wiring diagram for 05 KC
Tring to get remote turn on power for amps from passanger side fuse box. I would like to tap into wiring coming out of box. Anyone have the wiring diagram for that area? Thanks in advance.
conseit68 is offline   Reply With Quote
Old 09-22-2009, 07:24 AM   #2 (permalink)
Carbeaux's Avatar
Re: Need wiring diagram for 05 KC
Not sure if you want power on constantly, or switched with the ignition, but use one of the little gizmos in the link and you can tap into one of the two power points (cigarette lighters) in the center console. One is switched, the other constant on.
ATM Mini Add-A-Circuit Fuse Holder Tap
Hook 'Em Horns!
Old 09-22-2009, 07:50 AM   #3 (permalink)
Thank you sir...however, I am tring to aviod the "add-a-tap" and would prefer not to have to pull the radio back out (I do not know how many more times the clips can handle it)
Old 09-22-2009, 07:52 AM   #4 (permalink)
Carbeaux's Avatar
So how do you plan on getting your power? Are you just looking to find the right wire color and splice into it?
Hook 'Em Horns!
The Following User Says Thank You to Carbeaux For This Useful Post:
conseit68 (09-22-2009)
Old 09-22-2009, 07:59 AM   #5 (permalink)
correct...I believe the violet wire comes to the 10A Audio ACC location in the pass fuse box...plan is to splice into it behind the box...so I am looking for conformation via a diagram
Old 09-22-2009, 08:12 AM   #6 (permalink)
jmeyer's Avatar
PM me your email address and I'll send you the diagram. It is too large for me to attach here.
All I ask is that you just show up for whork!
HandyWhore™
jmeyer is offline   Reply With Quote
The Following User Says Thank You to jmeyer For This Useful Post:
Old 09-22-2009, 10:51 AM   #7 (permalink)
baseballfanz's Avatar
Go get you a volt meter.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 09-24-2009, 06:30 PM   #8 (permalink)
Workin'Titan's Avatar
This may be of some help if all you are looking for is the stereo. Scroll down the page and all the wiring is listed. Double check it against your truck and use the meter suggested by baseballfanz and all should go well.
2005 Nissan Titan Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Violet
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under the Driver Side Dash Near the Gas Pedal.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White/Black
Right Front Speaker Negative Wire (-): Blue/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Blue
Left Rear Speaker Negative Wire (-): Black/Yellow
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Red/Blue
Workin'Titan is offline   Reply With Quote
Old 09-24-2009, 10:22 PM   #9 (permalink)
gabriel c.'s Avatar
an installers best friend.
third coast titans
gabriel c. is offline   Reply With Quote
wiring diagram Just-in Titan General Discussion 0 11-02-2008 10:17 PM
stereo wiring diagram ditto874u2 Titan FAQ & Howto Area 2 05-14-2007 09:20 AM
Does anyone have a wiring diagram for the titan? Jeostang Titan General Discussion 4 01-11-2006 06:51 PM
Wiring Diagram acontisr Titan FAQ & Howto Area 3 07-16-2004 09:38 PM
Wiring diagram mm56 Titan General Discussion 12 06-29-2004 08:22 AM
