Re: Map light / dome light switch
awsome link but i cant find it on there.... ill post up pictuers of the thingee.
if you take the plastic clear lens down where the light shine out, ( the one you push to turn on the map lights) you can see the (white on the armada) on off switch.... going by that diagram it looks like part number [26432] LENS-MAP LAMP is the clear lens. this swith touches that lens to activate the map light.
Its not a big deal that map the light doesent work but for some reason with out that switch you dont have either front dome light.
