Old 07-06-2004, 05:21 PM   #16 (permalink)
canman's Avatar
Send a message via MSN to canman
Thanks. I did everything up to the filing point and got to where only 1 side would rub. I even went as far as hitting the clamp with a mallet to get it as far in as it would go, but I guess a little filing would probably make the difference and would not hurt anything.
canman is offline   Reply With Quote
Old 07-06-2004, 06:48 PM   #17 (permalink)
pciley's Avatar
Cessna, AWESOME!! Thanks for the time. Who knew you could get a camera in some of those places!!
Canman, Everything in those pics looked like a very clean install. I would like to make one suggestion though. DO NOT USE T-TAPS!!! Those little red pieces that were used to splice into the door lock wires, do yourself a favor and just strip the wires, wrap your cover's wires through the middle of the exposed wires around several times, and maybe even solder.. or just tape it off. Those T-taps have caused many installers millions of problems. I'm sure there is an installer who will back me up here... That is the quick way of doing it, but it can cuase problems down the line.
KC XE Smoke
Old 07-06-2004, 07:07 PM   #18 (permalink)
Pciley
You are right, they can cause problems. You can very easily cut the wires in half if you are not careful. I do avionics installations occasionally in aircraft, and these things are not to be used at all. I would have used some aviation connectors, but did not have any at the time. I will probably go back and redo this one day but it is what A.R.E sent. It will get me by for now.
Dann
cessna is offline   Reply With Quote
Old 07-07-2004, 04:09 PM   #19 (permalink)
canman's Avatar
Thanks for the input. I am at least moderately proficient at splicing wiring so I think I will avoid the t-taps. To be honest I have never even seen them before. I would probably kill one of my electricians if they used one so I will probably avoid them as well.
Old 07-07-2004, 10:44 PM   #20 (permalink)
pciley's Avatar
They sure make things easy, the trouble is that by design, they can cut through almost half of the original wire in the truck's wiring. Some picky ECUs or BCMs can notice the difference in resistance and throw a code or put a light on and then you are off to the dealer to get your wire harnesses's warranty voided.
Since they are very accessible and there's only two wires, you are probably going to solder right?
I prefer soldering, but with my alarm and the 35 wires I had to splice, there was no way I was going to lay upside down under the dash and drip solder in my eyes for 8 hours to get the job done... splicing sufficed there... and lots of split loom and electrical tape and some cursing too
KC XE Smoke
Old 03-04-2005, 05:39 AM   #21 (permalink)
Does anyone know why all of the pictures are no longer available on this thread? I am interested in seeing this install.
WVmtnbiker is offline   Reply With Quote
Old 11-05-2005, 11:44 PM   #22 (permalink)
pi3yeargrad's Avatar
WHAT HAPPENED TO THE PICS IN THIS THREAD??
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 11-07-2005, 06:54 PM   #23 (permalink)
JTD
You'll love the e-lock on your cover, it's nice to know when your walking away and hit the key fob you didn't forget to lock you cover.
2004 SE CC
Popular Pkg w/power captains
Off Road
Big Tow
Utility Bed Package
A.R.E. LSII
Billet bumper grill
Custom MagnaFlow 5X11 dual in/out
305-70-17 MTRs
Bushwacker Fender Flares
N-FAB NERF STEP
Donahoe coil-overs
Bilstein 5100 shocks
JTD is offline   Reply With Quote
