Re: How to get about 4" of lift without breaking the bank or going for a body lift.
body lift will give you 3. your pretty much maxed out suspension wise unless you go with coilovers and a small spacer. even then you'll be at like 8 overall.
__________________ 2011 White CC pro4x
Flowmaster Y
Banks Muffler
Airaid MXP 4" Intake
PRG UCA's
Extended travel Sway-Away 2.5 coilovers
PRG Camber Bolts
Homemade Traction Bars
Fuel Boost 18x9
Nitto Terra Grapplers 295/70 18
Front BORA 1.25 Wheel Adapters/ Pinch Weld Mod
6K HID's
10" Sub/Kenwood Amp
whats steering you away from body lift?? they work pretty decent with our trucks and will put you right about where you need for cheap if you install yourself
2004 4x4 LE CC Big Tow
CST 7inch, PA 3 inch Body lift, SAWs, Prg UCA's, Finned Diff Cover
17x9 -12 Kmc Xd hoss wheels,35x12.5x17 Cooper Discover s/t
Headlight mod,Grille mod, Axle vent mod, All day fab shackles
clearance for what? Itll give you plenty for larger tires. Your running a drop bracket lift kit. You cant really get good ground clearance no matter what. Unless you jack up the preload on coilovers. than it'll ride like sh!t and put a worse angle on your cv's. honestly, either a normal 6-7 inch lift (drop bracket) with a body lift or a bullet proof is what your stuck with for 4wd titans.
Flowmaster Y
Banks Muffler
PRG UCA's
PRG Camber Bolts
Fuel Boost 18x9
6K HID's
10" Sub/Kenwood Amp
took the words out of my mouth i had my coil overs cranked a big amount for about 5 months and went through 5 torn cv boots.. it was a hassle changing them out all the time.. so took the preload down and added the body lift for the height i wanted.. and ya the clearance is only from the tires on a 4wd.. pretty happy with how it is now and could put 38's on if i wanted
Nismo intake, 22 inch magnaflow dumped
Bedliner here and there
49 inch fender hieght
Tint, Vent Shades, Access Tonneau Cover
The Following User Says Thank You to cst_titan For This Useful Post:
I've done it myself and a friend if you are mechanically inclined it really isnt that bad 5 hours and it was done. Lots of ppl say it's bad I might of just had good luck. Just make sure you have the right tools for the job
Sent from my Autoguide iPhone app
