LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 08-28-2004, 04:49 PM   #1 (permalink)
Those with Bushwacker Flares
After installing my flares, I have noticed an open area behind the tire that is going to allow dirt, sand, road salt, etc to gather and sit between the flare and underside of fender. This is true especially on the front ones, but is also there on rear. Has anyone else noticed this, and been a concern to them? Here in Pa., where rust used to be a big problem with older designed cars, this makes me feel like this is asking for trouble! I think I am going to pick up some of the rubber/tar tape that is used for installing aftermarket windows in vans, and sunroofs. I will force it into those voids, then go back over with a cover of rtv silicone to seal it up. What are your thoughts and opinions? Below is a couple pics to show where I mean.
Born-4/27/04
Adopted-7/25/04
Smoke SE CC 4X4
Popular Captain, Big Tow, Utility Bed, Bed Extender, Fog Lights, Bushwacker Fender Flares, Floor Mats, XM SkiFi 2, OEM Seatcovers, Weathertech Vent Visors, Lund Intercepter Bug Shield, Challenger Tube Steps, Truxedo Low profile Tonneau Cover, Xpel Paint Protection, Gibson Stainless Single, Volant CAI, Airaid TB Spacer, PRG 2" Front 1" Rear, TM Bull Bar
BiXLL is offline   Reply With Quote
Old 08-28-2004, 05:13 PM   #2 (permalink)
IMADOGMAN's Avatar
BiXLL, If I am viewing this correctly, the second pic is looking forward from behind the lower edge of the flair. If you seal it up, then there will be no way for moisture to drain out that may get in anywhere else. These kind of moisture traps are what caused many of the older designs to rust away. I would just keep it rinsed out so that the salt doesn't have time to do it's corrosive thing. I live in UT and we just happen to have a great big lake full of salt nearby, so the Dept of Transportation uses lots of it cause it's cheap. Anyway, clean it often and park it inside if you can so that it can thaw and dry out...
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 08-28-2004, 05:15 PM   #3 (permalink)
IMADOGMAN's Avatar
Besides, from my experience, the RTV will fail, and it doesn't stick to the plastic/rubber in the long run...
IMADOGMAN
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 08-28-2004, 05:24 PM   #4 (permalink)
Good point, but what happens once you get stuff freezing in there, like "dingleberries" that hang off behind the tires in winter? Maybe try to seal off fender well part? (pic 1)
Born-4/27/04
Adopted-7/25/04
Smoke SE CC 4X4
Old 08-28-2004, 05:43 PM   #5 (permalink)
IMADOGMAN's Avatar
I don't have problems with the dingleberries because I park inside a garage where it generally stays above freezing, and they melt and fall off. We call them road-clinkers here, and we make "road clinker pudding" and serve it with "fog pot pie"...both are delicious served with green jello and hot cocoa...< both local religious foods
If it were me, I would try to hit the car wash often, even if it was just to wash the road clinkers off. Icy water is better than icy salt water... Anyone else have any ideas?
IMADOGMAN
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 08-28-2004, 05:57 PM   #6 (permalink)
Sammy Sandbag's Avatar
BiXLL, I wouldn't attempt to seal anything off on the flares, like IMADOGMAN said, it could just cause water to build up in there, plus you'll have a hard time actually sealing it off completely.
-Counsel Yourself
Old 08-28-2004, 06:00 PM   #7 (permalink)
IMADOG, sammy, thanks guys! What you say makes sense. I was just trying to head off any problems, but as you have stated, I may make more problems for myself. I guess thats what makes these forums so nice, being able to bounce ideas around.
Born-4/27/04
Adopted-7/25/04
Smoke SE CC 4X4
