Alignment - Page 4 - Nissan Titan Forum
post #46 of 54 (permalink) Old 01-10-2013, 05:29 PM Thread Starter
smdunn93's Avatar
iTrader Score: 0 reviews
Yeah definitely not on a budget for that haha have you heard anything about kyb quick struts? That's what the auto tech recommended at the other shop I went to that figured out my issue
smdunn93 is offline
Advertisement
post #47 of 54 (permalink) Old 01-12-2013, 07:16 PM Thread Starter
smdunn93's Avatar
If I ordered new oem springs from nissan and bilstein 5100 struts would this work?
Sent from my iPhone using AutoGuide.com Free App
smdunn93 is offline
post #48 of 54 (permalink) Old 01-12-2013, 07:33 PM
chadp82's Avatar
iTrader Score: 4 reviews
New springs and Bilsteins will take care of your springs and struts. If they are shot, this should raise the front some.
I am not familiar enough with the alignment stuff to know if it will give you enough to correct it. While you are it, it may be a good idea to replace with the fully adjustable cam bolts as well
05 LE Crew w/ Offroad Package
Bilstein 5100's; 1" Rear Lift Block & 1.5" Strut Spacer
BDPP (2° Advance, WOT removed, Regular Tune)
JBA cat back, Cajun Catless B Pipes
Airaid MXP Intake
Legit LED's
GO BRONCOS!!!
A glass of beer shortens your life by one minute, a glass of wine by two minutes, and a day of work by 7 to 10 hours
America!!! (Designed by geniuses, run by idiots)
chadp82 is offline
post #49 of 54 (permalink) Old 01-13-2013, 08:57 AM Thread Starter
smdunn93's Avatar
Good deal. If they work then it should solve my alignment issue too. The reason it's not aligning right is because I put a 4" lift on and my shocks and springs were already bad and so it made it even worse from the extra pressure of the lift giving me hardly any movement in my alignment
smdunn93 is offline
post #50 of 54 (permalink) Old 01-14-2013, 07:35 AM
Pops's Avatar
iTrader Score: 1 reviews
Re: Alignment
This will be the first time I've heard of Springs going bad. Shocks won't make a difference, you're not the first one to drive on bad shocks, I spent about 6-mos driving on shot shocks and there was no height difference. Bilstein are much better than KYB. I put a set of KYB GR2 on wife's Murano before we sold it and they're just a typical gas shock, seemed about the same quality as Monroe not bad but also not outstanding. KYB HD shocks work better than Bilstein on some 3/4-ton & 1-ton trucks but Bilstein seem to be a better fit on a Titan.
2005 Armada LE 4x4
Pops is offline
The Following 2 Users Say Thank You to Pops For This Useful Post:
chadp82 (01-14-2013), smdunn93 (01-14-2013)
post #51 of 54 (permalink) Old 01-14-2013, 08:53 AM
eddy18's Avatar
iTrader Score: 2 reviews
I'm goin to put 1.5" leveling kit on my 2010 CC 4WD on top of my bilsteins on the middle setting I know ill need an alignment, but will I need cambolts too?
Sent from my iPhone using AutoGuide.com App
2010 Nissan Titan CC SE 4X4
5100s Bilstein all around set to middle perch
1.5'' ebay Leveling Kit
Dirt King UCAs
PRG Sway Bar Endlinks
18''x9'' +12 offset Ballistic Jester wheels
Nitto Terra Grapplers 285/65R18
Full Interior/Exterior LEDs (Legit Accessories)
TO DO:
Bedliner
Grill
Front Window Tint
Nfab Prerunner bumper?
eddy18 is offline
post #52 of 54 (permalink) Old 01-14-2013, 09:10 AM
Pops's Avatar
Re: Alignment
Likely... Anything more than 1" difference usually needs Cam Bolts.
2005 Armada LE 4x4
Pops is offline
post #53 of 54 (permalink) Old 01-14-2013, 10:46 AM
eddy18's Avatar
So I should order them...would the alignment shop put them?
Dirt King UCAs
TO DO:
Bedliner
Grill
Front Window Tint
eddy18 is offline
post #54 of 54 (permalink) Old 01-14-2013, 12:06 PM Thread Starter
smdunn93's Avatar
@pops we'll see how it works and I'll let you guys know when I'm done.
smdunn93 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Got an alignment... 54warrior Titan Suspension 10 02-24-2010 09:26 AM
Alignment ?? mcaro Titan General Discussion 5 09-14-2007 12:14 PM
Alignment After PRG JerseyTitan Titan General Discussion 4 08-30-2005 07:21 AM
Alignment always necessary after PRG? engine17 Titan Suspension 7 08-14-2005 07:00 PM
Alignment?? jd1973 Titan Wheels, Tires & Brakes 6 08-11-2005 05:59 PM
You may post new threads
You may post replies
