Alignment - Nissan Titan Forum
Old 01-09-2013, 08:45 AM   #1 (permalink)
smdunn93's Avatar
iTrader Score: 0 reviews
Alignment
My camber is at -1.2 on the left and -1.5 on the right after my alignment. The tech at the local shop said its maxed out is that true? Also I have a 4" spindle lift and looking to add bilsteins on mid level. Will I be able to get my truck aligned? It's a 2006 rwd.
Sent from my iPhone using AutoGuide.com Free App
smdunn93 is offline   Reply With Quote
Advertisement
Old 01-09-2013, 11:39 AM   #2 (permalink)
Re: Alignment
sounds like you need new camber bolts, almost a must on anything over 2" to keep camber correct, can be found from prg,
iam_canadian22 is offline   Reply With Quote
Old 01-09-2013, 11:42 AM   #3 (permalink)
Pops's Avatar
iTrader Score: 1 reviews
Re: Alignment
Didn't 2006 still come with Cam Bolts? I'd crawl under there and look at them myself, it's pretty easy to tell.
2005 Armada LE 4x4
Old 01-09-2013, 11:43 AM   #4 (permalink)
Carbeaux's Avatar
iTrader Score: 12 reviews
Re: Alignment
Unfortunately, they did not, Pops. Ask me how I know.
But to the OP, that's what you'll need to get your alignment right.
Hook 'Em Horns!
AKA TroubleWhore™AKA HitAndMissWhore™AKA RockyWhore™AKA SigPicNaziWhore™
ΜΟΛΩΝ ΛΑΒΕ
The Following User Says Thank You to Carbeaux For This Useful Post:
Pops (01-09-2013)
Old 01-09-2013, 11:47 AM   #5 (permalink)
Pops's Avatar
Re: Alignment
Makes me glad I have an '05.
2005 Armada LE 4x4
The Following User Says Thank You to Pops For This Useful Post:
Carbeaux (01-09-2013)
Old 01-09-2013, 12:23 PM   #6 (permalink)
chadp82's Avatar
iTrader Score: 4 reviews
Re: Alignment
I got an alignment done yesterday after installing a 1.5" strut spacer on top os Bilstein 5100's this weekend. I know I have the adjustable cam bolts. They got things in spec, but said I am maxed out. If anything ever changes, I will need new cam bolts, but good for now.
05 LE Crew w/ Offroad Package
Bilstein 5100's
1" Rear Lift Block & 1.5" Strut Spacer
BDPP (2° Advance, WOT removed, Regular Tune)
JBA cat back, Nightowl B Pipes
Airaid MXP Intake
I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day. ~ Frank Sinatra
GO BRONCOS!!!
chadp82 is offline   Reply With Quote
Old 01-09-2013, 01:28 PM   #7 (permalink)
smdunn93's Avatar
Well I looked the other day under neath and I have what looks like eccentric washer to adjust it. are the other camber bolts just longer? Or what's the biggest difference?
Old 01-09-2013, 01:31 PM   #8 (permalink)
Pops's Avatar
Re: Alignment
If you have them, you have them... ProComp ones are very slightly more off-center and give a tiny bit more adjustment but that's it, I don't think it's enough to justify changing them, but that's just my opinion.
2005 Armada LE 4x4
Old 01-09-2013, 01:54 PM   #9 (permalink)
smdunn93's Avatar
Is this what they look like?
Old 01-09-2013, 02:03 PM   #10 (permalink)
Pops's Avatar
Re: Alignment
Yes! That's definitely an Eccentric Bolt so you should be good to go. That one looks like it's maxed out bringing the bottom of the tire in to the inside.
2005 Armada LE 4x4
Old 01-09-2013, 02:04 PM   #11 (permalink)
RCHGVR's Avatar
iTrader Score: 7 reviews
Re: Alignment
Originally Posted by smdunn93 View Post
Attachment 153163
Yes ( I really hate this stupid ten character rule)
HID's:
5000K lows 3000k Fogs
Custom Custom exhaust
bilstein 5100 hd on all 4 corners
Is a V8 what was I thinking
RCHGVR is offline   Reply With Quote
Old 01-09-2013, 02:07 PM   #12 (permalink)
Pops's Avatar
Re: Alignment
Ten ..........
2005 Armada LE 4x4
Old 01-09-2013, 04:08 PM   #13 (permalink)
smdunn93's Avatar
Like in towards the truck? If that's the case it may be even more messed up than I thought cause it looks as if the bottom of the tire sticks out further than the top. Here's a pic of the alignment sheet itself Alignment-imageuploadedbyag-free1357776528.507431.jpg
Old 01-09-2013, 04:12 PM   #14 (permalink)
smdunn93's Avatar
Will these bolts work? They're a hell of a lot cheaper haha
http://www.jcwhitney.com/alignment-c...6966y2006g26j1
Old 01-09-2013, 04:20 PM   #15 (permalink)
jtrick's Avatar
iTrader Score: 5 reviews
Someone here should be able to tell you if any aftermarket bolts provide more adjustment than OEM.
Sent from my T
2008 Crew Cab 2WD
2.5" Front, 1.5" Rear Lift
Billstein 5100's on Middle Perch
PRG Extended Endlinks
2" Wheel Adapters
BDGT Tuned with RAM Mount
Airraid MXP CAI
Flowmaster Exhaust
275/70R/18 Nitto Terra Grapplers
Bedlined Everything
Legit 8k High and Low HIDS
Legit Blue interior LED package
20% Tinted Front Windows
jtrick is offline   Reply With Quote
Advertisement
Got an alignment... 54warrior Titan Suspension 10 02-24-2010 09:26 AM
Alignment ?? mcaro Titan General Discussion 5 09-14-2007 12:14 PM
Alignment After PRG JerseyTitan Titan General Discussion 4 08-30-2005 07:21 AM
Alignment always necessary after PRG? engine17 Titan Suspension 7 08-14-2005 07:00 PM
Alignment?? jd1973 Titan Wheels, Tires & Brakes 6 08-11-2005 05:59 PM
SEO by vBSEO 3.3.2
