Help with halo wiring - Nissan Titan Forum
Old 02-04-2013, 06:42 AM   #1 (permalink)
mississippititan30's Avatar
iTrader Score: 13 reviews
I will soon be wiring up a bunch of stuff and was wanting some guidance before the job starts. I'm wanting to run all the halos to a switch in the truck. There will be 2 different halos so I want them to run to two different switches. Could someone maybe make a simple diagram to show me the best way of doing this? And what parts do I need to buy to make this as easy as possible. This is my first wiring project so any input you have would be much appreciated! Thanks
"First it's pretty tires, then it's pretty guns...next thing you know, you're shavin' your beard and wearin' capri pants." - Si
mississippititan30 is online now   Reply With Quote
Advertisement
Old 02-04-2013, 06:55 AM   #2 (permalink)
Carbeaux's Avatar
iTrader Score: 12 reviews
Re: Help with halo wiring
http://www.titantalk.com/forums/3013072-post8.html
Look at the post above. You're basically going to have TWO of those circuits in the diagram, and you'll have TWO wires running out of the cab to the halos. If the halos are LED, they won't likely draw too much power so you might be able to get away without the relay, but my suggestion is to put it in. I don't believe in drawing too much power off the existing harness.
You can run 16 gauge from the fuse box to the switches and out through the firewall. Run 12 ga. as the ground, from the battery and to the lights. The 12 ga. is overkill, but I'd rather they be more than sufficient and not be subject to heating up from trying to carry too much amperage. 14 ga. would probably me more than sufficient.
Hook 'Em Horns!
AKA TroubleWhore™AKA HitAndMissWhore™AKA RockyWhore™AKA SigPicNaziWhore™
ΜΟΛΩΝ ΛΑΒΕ
The Following 2 Users Say Thank You to Carbeaux For This Useful Post:
baseballfanz (02-04-2013), mississippititan30 (02-04-2013)
Old 02-04-2013, 07:00 AM   #3 (permalink)
Yeah they're LED, but i defiantly want the relay hooked up. What exactly is the indicator switch for? I'm going to be using a rocker switch that I ordered online and not a toggle if that matters.
Also, will this let the lights come on separately? I want them to come on separate. Will I need 2 relays?
Old 02-04-2013, 07:07 AM   #4 (permalink)
baseballfanz's Avatar
iTrader Score: 1 reviews
Just treat each one as an independent light. As long as you hook them up independently from each other they will come on separately. So yeah two relays needed. As for the switch, toggle or rocker it still wire in the same
Posted from my Titan.
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is online now   Reply With Quote
The Following User Says Thank You to baseballfanz For This Useful Post:
Carbeaux (02-04-2013)
Old 02-04-2013, 07:12 AM   #5 (permalink)
Carbeaux's Avatar
The indicator light is optional, and may or may not be inside the switch. Yes, you'll need two relays. BBF is correct. Treat each one as an independent light, because they are. Two complete circuits, one for each halo setup. That will insure you'll be able to have one or the other or both on at the same time. Rocker or toggle switch makes no difference.
Hook 'Em Horns!
ΜΟΛΩΝ ΛΑΒΕ
Old 02-04-2013, 07:15 AM   #6 (permalink)
Thank you both. Electrical stuff make me a bit nervous. Wanna make sure I don't ruin something lol.
The Following User Says Thank You to mississippititan30 For This Useful Post:
Old 02-04-2013, 08:59 AM   #7 (permalink)
SirDukeDH's Avatar
iTrader Score: 2 reviews
I'm running at least 500 leds on my truck and only using a 30 amp fuse. Been so for years. And I just ran my bed light kit with out the relay with no probs. That's 16 feet of leds off the battery. Running a duralast gold bat for now. I wouldn't go too heavy on the gauge either. 14 or 16 gauge is fine for led lights.
Sent from my SCH-I535 using AutoGuide.Com Free App
04 XE. Motto Metal 909's 18's,Airaid MXP CAI, Banks Monster muffler, Leaf spring helper mod, green LED lights in grill and fog lights, green interior lights(under construction), Ferreus Custom Skull grill, 35% Tint, Trifecta tonneau cover, Azetta Tails, bedlined rear bumper, air ram mod, armada air dam, Eye Lid mod, Airaid TSB, Screen delete mod, Axle Vent mod
SirDukeDH is offline   Reply With Quote
The Following 2 Users Say Thank You to SirDukeDH For This Useful Post:
Old 02-04-2013, 09:58 AM   #8 (permalink)
I know I don't exactly need the relay, but it's just to make me feel better about the install. Lol. Plus my truck only had 8k miles and still has the stock battery so hoping the relay will a least help a little. How should I run the wire to the cab? Drill through the firewall? Or is there a pre existing hole I can feed it through?
Old 02-04-2013, 10:29 AM   #9 (permalink)
I used the rubber grommet where the hood release cable pass through the firewall. Push a metal shirt hanger through it from the inside to the engine bay.
Attach your wires to it and pull it back through.
The Following 2 Users Say Thank You to baseballfanz For This Useful Post:
Carbeaux (02-04-2013), SirDukeDH (02-04-2013)
Old 02-04-2013, 11:20 AM   #10 (permalink)
Carbeaux's Avatar
Ditto this. Exactly what I did. I have 3 small gauge wires running out of there to various aux lights.
Hook 'Em Horns!
ΜΟΛΩΝ ΛΑΒΕ
Old 02-04-2013, 12:00 PM   #11 (permalink)
Awesome! Thanks! Any kind of little parts I should buy the make this job easier? Splicers and things like that?
Old 02-04-2013, 12:46 PM   #12 (permalink)
Carbeaux's Avatar
It'll help. Most of my connections are done using the butt type of crimp connector. I suck at soldering.
Hook 'Em Horns!
ΜΟΛΩΝ ΛΑΒΕ
Old 02-04-2013, 02:55 PM   #13 (permalink)
Ya I'm not soldering. Butt type crimp connector? I'm illiterate with all things electrical. Lol
Old 02-04-2013, 02:59 PM   #14 (permalink)
Butt crimp connectors
You can go to Autozone or any auto parts store and get a "kit" that has an assortment of connectors.
Old 02-04-2013, 03:01 PM   #15 (permalink)
SirDukeDH's Avatar
i used the same hole for running wire. you can use any type of connector you feel will work. I use twist style, butt crimp style, twist crimp style. i suck at soldering too. just finally learned when i had to do my bed lights. and i don't know about you guys, but liquid tape has become my good friend.
Advertisement
Any tips for wiring up my new Spyder CCFL Halo/Projectors? Lurchdubious Electrical & Wiring 12 03-30-2013 10:32 PM
How to: Mrmegnum's Halo Mod Mrmegnum Titan FAQ & Howto Area 12 10-20-2011 06:32 PM
20% off Halo anyone? sparkplugs.com Sparkplugs.com 0 04-15-2010 02:11 PM
Halo Led??? jkelley3209 Titan Visual & Audio Discussion 9 04-18-2007 11:19 AM
They said this day would never come..Halo 2 is HERE!! TranMan409 Off-Topic Discussion 9 11-10-2004 04:24 PM
SEO by vBSEO 3.3.2
