Old 09-21-2004, 10:00 PM   #1 (permalink)
Dashboard Switches
I'm going to be installing some extra lighting in my Titan and I'd like to use one of the blank switch areas on my dash.
Does anyone know if Nissan (or anyone) sells a blank switch that doesn't light up when the headlights are on?
I would prefer not to use one of the OEM pre-labeled switches.
ITSDREW is offline   Reply With Quote
Old 09-22-2004, 07:17 AM   #2 (permalink)
schneid's Avatar
I had the link once
but can't find it now. I think it is a common Nissan part and was listed as an an Xterra accessory. I'll keep looking.
schneid is offline   Reply With Quote
Old 09-22-2004, 09:43 AM   #3 (permalink)
If you can't find a Nissan switch that you like, you can just drill the switch blank and mount an aftermarket switch through the switch blank. There was a post here quite awhile ago that the dealer wanted $45 for a Nissan switch.
Old 09-23-2004, 02:55 AM   #4 (permalink)
Originally Posted by BigRedTitan
Fog Light switch installed
I got my Fog Light switch today. I got it from Jamie at Nissanparts247.com. Part number is 999F1-6E000. Price was $20.45 delivered. This switch is for Nissan trucks and Pathy's after 1994. It took about two months to get it due to being BACKORDERED. I think it was worth the wait though. I now have a factory Fog Light switch. Yeeeeeaaaaaaaaa!! Looks much better than the aftermarket rocker I had.
Hope this helps, I'd rather it look somewhat factory and pay $21 as opposed to a jainky AutoZone switch...
SmokenTitan is offline   Reply With Quote
Old 09-23-2004, 08:45 AM   #5 (permalink)
$21 for a rocker switch? Does it come with a jar of vaseline?
http://www.colehersee.com/pdf/master_cat/b_toggles.PDF
Old 09-24-2004, 07:36 AM   #6 (permalink)
Maybe the bottom two, I wouldnt consider the top two...
Do you give the vaseline speach to the gas pump when you fill up?
Sorry I tried to help...
Old 09-24-2004, 07:54 AM   #7 (permalink)
40-Dan's Avatar
check w/ Mouser Electronics www.mouser.com
I just ordered a couple of their Carling rocker switches that should look VERY close to stock (at least as close as some of the Cole Hersee switches). They were about $6 each for a DPDT. Other styles are probably a bit cheaper.
Dan
Smoke '04 Titan LE 4x4 CC
Off Road Pkg w/ VDC, Big Tow, Sunroof, DVD
40-Dan is offline   Reply With Quote
Old 05-27-2008, 09:12 AM   #8 (permalink)
Re: Dashboard Switches
Dan
What is the part number for the switches you ordered from mouser.
TIA
-Deryl
Turnfast77 is offline   Reply With Quote
Old 05-27-2008, 09:29 AM   #9 (permalink)
roy365's Avatar
Now that wasnt very necessary........
Autozone sells lighted, non lighted whatever you like. If you dont want the light to work....just dont wire it so it comes on. And if you mess up a cover they cost about 5-10 bucks for a replacement cover that is OEM. Not a bad idea to have a few around. I ordered a few and THEN worked on them so all i had to do was pull the dash and install.
Good luck!
0-60MPH@5.60 & 1/4 mile@14.25 F/S/T
Mods list: http://www.titantalk.com/forums/memb...ml#vmessage205
roy365 is offline   Reply With Quote
Old 05-28-2008, 05:56 PM   #10 (permalink)
jason27's Avatar
www.partsexpress.com might have something similar
jason27 is offline   Reply With Quote
