Old 12-08-2004, 02:27 PM   #1 (permalink)
CoachBoone's Avatar
Replacing VS. repairing the hood
I got a couple dings in my hood a month or so ago when some road trash got kicked up and hit me, but I've put off getting it repaired because there small and the paint is ok. Well, today I got an estimate for $561, which was discounted from $661. One of the dings is on that sharp seam....or should I say crease and has to be filled, so it's not a slam dunk. The local dealer quoted me a new hood, unpainted for $552.00. Anyone know a good wholesaler that could hook me up, painted or un? I'm in Portland, Orygun.
Old 12-08-2004, 02:39 PM   #2 (permalink)
QWIKWHIP's Avatar
Have you looked into paintless dent repairs? My dealer put 2 nice dents in my hood right on the front bend and they had them removed by a ding repair guy and you can't even see were they were. That should only cost about $100 or so.
Old 12-08-2004, 02:46 PM   #3 (permalink)
CoachBoone's Avatar
Paintless is great, but they have to be somewhat smooth dents. The one on the crease.....where the hood slopes down to the side, is kind of square....it's on an angle, can't PDR that.
Old 12-08-2004, 03:48 PM   #4 (permalink)
phillipyang's Avatar
Send a message via AIM to phillipyang
Try asking the professional if they can perform the paintless dent repair. If that doesn't work, here is a site that you can get stuff for cheap.
Picture of the Front Section
Hood 2004 $323.23
Nissan Parts Cheap (Front Parts Section)
Hope that helps
Nissan Titan LE 4x2 CC
Purchased: Feb 2004
Miles to date: 74,000 (Since Feb, 15 2004)
Mods: Banks Cat Back Exhaust System, K&N with arbox mod, Front Air Dam, Custom bed cover, AC/DC interior conversion, PSP/Ipod Dock
http://www.phillipyang.com
phillipyang is offline   Reply With Quote
Old 12-08-2004, 03:48 PM   #5 (permalink)
pagerdaddy's Avatar
You should have seen the creases in the rear of my bed when I backed into
a mailbox. Found a PDR guy who had been doing it for seven years. He got
the dent in the hood out which was right in the curve also.
Be worth a shot to let one of those guys look at it, anyway.
Steve
pagerdaddy is offline   Reply With Quote
Old 12-08-2004, 07:40 PM   #6 (permalink)
QWIKWHIP's Avatar
I would at least have them look at it. They can do some amazing things.
Old 12-09-2004, 11:51 AM   #7 (permalink)
CoachBoone's Avatar
Hood 2004 $323.23
Hope that helps
Hey thanks!
I might get in touch with them.
Awesome!
Old 12-10-2004, 11:57 AM   #8 (permalink)
rjspitz's Avatar
Hood 2004 $323.23
Hope that helps
Good find, but this site is a little cheaper. I've had very good luck with them. www.nissanpart4u.com in Gwinnet, GA. Although, www.nissanpartscheap.com is in CA, a bit closer. Good luck.
Old 12-11-2004, 12:30 PM   #9 (permalink)
pciley's Avatar
Coach, I do PDR for a living, take dents out of body lines all the time. No big deal, I don't even charge extra for those. Check around, I'm sure your local guys can help you out! Hopefully save you $450 or so from the difference of the repair vs. replacing.
ALSO, keep in mind, if you are very picky you will always know the truck has been painted. If you get a new hood painted or repaint your repaired hood, they will most likely blend the clear into your fenders and maybe even the A-pillars. I wouldn't want this on my truck.
Titan hoods have made me quite a bit of money
I have done a few recently for dealerships where the mechanic slammed the hood by hand and they want it fixed before the customer even sees their truck.
KC XE Smoke
Old 12-12-2004, 09:53 AM   #10 (permalink)
pagerdaddy's Avatar
Does that mean I'm now qualified as a Nissan technician?
It's pretty neat to watch you PDR guys do your thing on these dents. The
guy who did mine took out the tail light and drilled a hole in there to get at
the crease I put in the bed.
Steve
