Old 01-29-2005, 07:37 PM   #1 (permalink)
Exclamation Need Help With Level Kit Install!!!
i have the off road pkg. just installed strut, lifted lower control arm with a jack and pulled down the upper control arm but i have maybe another 3/4 of an inch to tighten it and the upper control arm is hitting the bracket that holds the strut in place. can anyone help??
thanks jim
I ALSO POSTED THIS IN THE GENERAL SECTION
sxviper is offline   Reply With Quote
Old 01-29-2005, 07:50 PM   #2 (permalink)
Banned
Squid's Avatar
Did a search and this is prerunner gregs kit install in PDF.
http://performancelifts.com/installa.../GMTITANLK.pdf
Hope it helps.
Squid is offline   Reply With Quote
Old 01-29-2005, 07:57 PM   #3 (permalink)
i have those in hand but they don't say anything about it hiiting the bracket and what to do. thanks
Old 01-29-2005, 08:05 PM   #4 (permalink)
Mike H.'s Avatar
I had a tough time. See Front is done. Rear is next.
Try a small turnbuckle and some wire attaching the upper and lower arms together, and then tighten the turnbuckle to pull the two arms together gradually until you can finally start the ball joint nut.
Mod links (clickable):
Old 01-29-2005, 08:08 PM   #5 (permalink)
Banned
Squid's Avatar
Thanks Mike for baling me out. Having not done the install, SEARCH was all I could do.
Old 01-29-2005, 08:08 PM   #6 (permalink)
i have the nut started but the upper control arm is hitting the bracket that the strut mounts into and i don't have the nut tight yet?
Old 01-29-2005, 08:47 PM   #7 (permalink)
vector6's Avatar
put a floor jack under the lower control arm and raise it... it will raise the truck a little but it will also but dont worry about that.
2006 jeep RUBICON so long titan...
No News with Combat Crews
vector6 is offline   Reply With Quote
Old 01-29-2005, 08:57 PM   #8 (permalink)
1BadTitan's Avatar
OH YEA!!! You have the OR pkg like me.You have to unbolt the lower sway bar. Thats what I had to do. Its counterbalancing with the weight of the other side.
1BadTitan
BASICS: Black LE KingCab 4x4-Off Road Pkg-Utility Track Bed-Big Tow Pkg
EXTERIOR: 10,000K HID Headlight Conversion-AVS Bugflector II-Wade In Channel Rain Gaurds-Smoke Headlight Reflectors-Shaved Emblems-Painted Red Calipers-Smoke Taillights-Stainless Nerf Bars-Shorty Billet Antenna-20% Tint-5" Exhaust Tip-DIY Custom 3rd Brake Light-Tailgate Assist-Custom Home Made Hitch Cover
INTERIOR: Shortened Shifter-Nismo Pedals-Dynamat Everywhere-Factory Cointray-Carbon Fiber Accents
ROLLERS: Stock OR 17's With Nitto Terra Grapplers 295/70/17
ENGINE & PERFORMANCE: PRG Lift Kit-Nismo Billet Oil Cap-Platinum Terminals-Fram AirHog Filter-Slotted Cross Drilled Rotors
I.C.E.: Eclipse AVN2454-JL Audio TR650 6 1/2 Coaxials-JL Audio TR650 6 1/2 Components-Hardwired Radar Detecter-Add On Remote Start-MICRO Alarm
Other Rides: 05 Suzuki GSXR-03 Suzuki Quadracer LTZ-400
Old 01-29-2005, 09:06 PM   #9 (permalink)
ok guy's, i have a jack under the lower arm until the truck lifts up, and i have the swaybar off at each side. what in h*ll am i doing wrong??????? i even took the strut out again to try it again and the same thing is happening
thanks jim
Old 01-29-2005, 10:33 PM   #10 (permalink)
1BadTitan's Avatar
If you get the nut started, use an impact to get it tight then set it down...It will settle.
1BadTitan
Old 01-29-2005, 11:47 PM   #11 (permalink)
loufish's Avatar
Be careful with a impact, go easy, that nut isn't very thick, and might strip if you go gorilla on the gun....
When you have the frt end aligned, have the shop loosen, then re-tighten the upper arm bushings. This will increase the upper arm bushing life....
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 01-30-2005, 03:06 PM   #12 (permalink)
Talking
spoke with greg today and all is well, i just had to have the other side tire on and the lower arm compressed the strut with no problem. truck looks awesome. thanks again greg.
Old 01-30-2005, 03:09 PM   #13 (permalink)
Stevencraver's Avatar
Originally Posted by sxviper
spoke with greg today and all is well, i just had to have the other side tire on and the lower arm compressed the strut with no problem. truck looks awsome. thanks again greg.
Truck looks awesome....where are some pics!
4X4 SE CC OR BT RF UB
PRG UP FRONT
295/70/17 TERRA GRAPPLERS
Stevencraver is offline   Reply With Quote
Old 01-30-2005, 06:03 PM   #14 (permalink)
Talking
I Will Try To Get Some Pic's Tommrow.
