Old 02-12-2005, 04:40 AM   #1 (permalink)
m4ck's Avatar
Need help guys Question about Aries offroad Oval steps
I need some help guys. I found these Aries Offroad Oval Black steps for the Crew Cab. I have a King Cab and Can't find them for the KC. This place has a great price on these and I would like to get them. My question is this. Are the mounting points the same for the CC and the KC's for the steps. Or are the CC's a longer step. I would think it would still be the same especially if the two have the same wheel base. Does anyone know if the wheel base is the same. If you know where I can find these for the KC then I won't even worry about all this I will just get them.
thanks for the help
Duh guess it would help to see what I'm looking at. http://www.truckxccessory.com/arot-229006.html
M4ck
m4ck is offline   Reply With Quote
Old 02-12-2005, 05:47 AM   #2 (permalink)
ICE17N24's Avatar
thanks for the help
M4ck
Did you ever find out the answer to your Aries off road oval step question?? I can't answer the question but I might be able to help.
I have the CC with the Aries O.R. Ovals. If you would like for me to measure the spread between the bolts, or the overall lenth of the tubes or anything, let me know.
LATER
ICE
BTW: You never put in the place where you saw them or the price. I paid $275 shipped for mine.
2004 Red Brawn XE CC 4x2, No performance mods (engine is stock)
Born on 9/04
Visual mods:
Tint
Aries Offroad Black Oval Nerf Bars
Nissan hitch
Extang RT cover
PRG leveling kit (AWESOME, THANKS Greg)
2005 Excursion 6.0L PSD 4x4 Limited Mineral Grey (The wife's vehicle)
ICE17N24 is offline   Reply With Quote
Old 02-12-2005, 06:09 AM   #3 (permalink)
CaliforniaTitan's Avatar
I have a KC and could measure the mounting bolt distances on it for you to compare.
Chris
Old 02-12-2005, 01:29 PM   #4 (permalink)
m4ck's Avatar
Yeh woops I forgot to give the link I edited my post for ya. http://www.truckxccessory.com/arot-229006.html
M4ck
Old 02-12-2005, 01:34 PM   #5 (permalink)
I have the Aries Oval in stainless... they are exatly the same as the Crew Cab version. When I recieved them I noticed that the rear step is the same size as the front step. So I called Aries to verify that I didn't receive the crew cab version instead of the King Cab! He told me that they were exactly the same... no difference between the kits! I mounted them with the miserable instructions that they give and they are great. If you buy them a few things to note is that there are 2 different size washers! When you look at them you won't think there is a difference and the instructions make no mention of them. Use the slightly thicker washers to go underneath the Aries steps. The thinner washer goes on the bolts that connect to your truck! This will save you alot of time on the install as the thinner washer will not fit on the bolts that connect the Aries steps. Also, the instructions say that the brackets will be labled and they won't be. The front 2 brackets will be identical but the 3rd bracket that mounts nearest the bed will have its mounting point flipped towards the front of the truck! Once you see them you will now exactly what I am talking about! The instructions are piss, but the install is relativly painless once you get going! They really do look factory and you can't beat the price. I bought mine off of ebay as a previous poster found the link. http://cgi.ebay.com/ebaymotors/ws/eB...953872512&rd=1
$276.00 delivered
King_TitanIII is offline   Reply With Quote
Old 02-12-2005, 01:41 PM   #6 (permalink)
npep's Avatar
Send a message via AIM to npep
I wish I had those directions before I did mine month or so ago...
Directions = BAD
Aries Oval = GOOD
$276.00 delivered
2004 Titan SE CC
Smoke
Mods:
Fog lights
Bug Deflector
Window Deflectors
Aries Step Bars
Undercover Tonneau
Factory DVD System
npep is offline   Reply With Quote
Old 02-12-2005, 01:57 PM   #7 (permalink)
ICE17N24's Avatar
I have the Aries Oval in stainless... they are exatly the same as the Crew Cab version.... If you buy them a few things to note is that there are 2 different size washers! When you look at them you won't think there is a difference and the instructions make no mention of them. Use the slightly thicker washers to go underneath the Aries steps. The thinner washer goes on the bolts that connect to your truck! This will save you alot of time on the install as the thinner washer will not fit on the bolts that connect the Aries steps. Also, the instructions say that the brackets will be labled and they won't be. The front 2 brackets will be identical but the 3rd bracket that mounts nearest the bed will have its mounting point flipped towards the front of the truck! Once you see them you will now exactly what I am talking about! The instructions are piss, but the install is relativly painless once you get going! ...
EXACTLY, I agree with you and npep. The bars are nice the instructions SUCK!!!
Born on 9/04
Visual mods:
Tint
Nissan hitch
Extang RT cover
Old 02-12-2005, 03:07 PM   #8 (permalink)
hernan28's Avatar
$276.00 delivered
King - I agree with you, I bought mine through truckxccesory and yes the instruction says they are labeled and nothing was labeled. I paid $273.00 delivered, I got the OR Oval Nerf Bars - Black
Tom
2004 Titan XE CC 4X2 - Deep Water
Born on Date - 9/04
Adopted on Date - 11/06/04
Preferred Package -
Am/FM/CD (6 Disc In-Dash) Audio System, Overhead Center Console, Remote Keyless Entry, Vehicle Security System, Floor Mats,
Drop-in Bedliner w/Non-Sliding Bed Extender, Nissan Bug Deflector.
Mods - Access Roll-up Cover, Aries Black Oval OR Nerf Bars, Splash Guards, MB Offroad Gunner 6 20x8.5 wheels and Goodyear Eagle GTII 305/50R-20 tires, K&N Drop-In Filter.
hernan28 is offline   Reply With Quote
Old 02-12-2005, 03:25 PM   #9 (permalink)
hernan28's Avatar
just a test
need-help-guys-question-about-aries-offroad-oval-steps-2004-titan-cc-xe-4x2-4-.jpg.jpg
Born on Date - 9/04
Preferred Package -
Old 02-12-2005, 06:17 PM   #10 (permalink)
m4ck's Avatar
Do any of you guys have a decent bigger picture of them on your truck. I really want to see these things up closer.
THanks for all the help too.
M4ck
Old 02-22-2005, 12:08 PM   #11 (permalink)
Tx_flip's Avatar
ICE & Hernan,
Could you let me know where you purchased your Aries Oval Black bars for around 270+ shipped? Thanks ya'll.
2007 FJ Cruiser...will miss my Titan
Tx_flip is offline   Reply With Quote
