Old 04-12-2005, 06:11 PM   #1 (permalink)
m0wens's Avatar
Tires & Rims
Has anyone had any problems with the tire preasure light coming on after upgrading there tires and rims? I'm looking at upgrading my rims and tires from 18's to 20's. I didn't know if this would be an issue or not.
My Titan Gallery
2005 Nissan Titan LE 4x4 Smoke w/Big Tow Pkg
305/55/R20 Nitto Terra Grapplers N2 20x9 Rims By MC2 - DF Flowmaster 50 Series Exhaust w/MF Tips - *2 Degree Timing Advance - OEM Bugshield / OEM Step Rails - Utilitrack System w/Bed Extender - Undercover Tonneau HardCover - Westin Chrome Bullbars
New Toy - 2008 Super Bee SRT-8 #581 of #1000 - Fully Loaded w/ Option Groups I, II, III - Sunroof - Airbags Front & Side - Remote Start - Best Times 0-60 4.578sec - 1/4mile in 12.9567 Out Of the Box.
m0wens is offline   Reply With Quote
Old 04-12-2005, 06:32 PM   #2 (permalink)
ensclark's Avatar
Send a message via AIM to ensclark
I haven't had a problem at all. They have been in for 6 months and 7k miles or so.
White LE CC 4X4, OffRoad, Big Tow,Nav, DVD, back up sonar, sun roof, bug and window deflectors, Westin Bull Bar, K&N aircharger, A.R.E. bed cover, Centerline Stingray III's 17X8s, Utility Bed Package, W/ sliding bed extender and divider, Side air bags, all leather, Captain chairs. http://www.nitrousenterprises.com/ 3 inch Lift Kit. BFG 315/70-17 A/T
ensclark is offline   Reply With Quote
Old 04-12-2005, 07:39 PM   #3 (permalink)
Wheels
When you guys change rims on the Titan are you just pulling out the sensors from the stock rims and placing them on the new rims? Are the tire pressure sensors in the Titan in the valve steams?
Thanks,
UNDERDOG
UNDERDOG is offline   Reply With Quote
Old 04-12-2005, 09:45 PM   #4 (permalink)
Vegas04's Avatar
yes, they are incorporated into the rim's valve. It looks like a little grey cube inside the wheel.
Some people switch to the new rim, some people just sell them to someone else. If you dump them, the receiver under the body of the truck will look for a signal for about forty-five minutes and then finally give up and turn on the low-pressure-light without the audible alarm. I got rid of my tire-press sensors in January and have only had the light come on about three times. BTW the light resets by turning the key to off.
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
Vegas04 is offline   Reply With Quote
Old 04-13-2005, 08:17 AM   #5 (permalink)
m0wens's Avatar
Hey Vegas04,
Is it a pain to switch the sensor from one rim to the other? Or do I I need to take it to the dealership to have it done once I get my new rims and tires?
My Titan Gallery
Old 04-13-2005, 08:19 AM   #6 (permalink)
VShortt's Avatar
Can you retrofit them in any wheel application.
New List of Mods Coming soon
Old 04-13-2005, 08:28 AM   #7 (permalink)
TIsTAN's Avatar
your new wheels will need to be able to accept the oem sensors. since the stem and sensor is a single unit, the bottom of it is (fairly) flat. therefore, your wheels must have a flat spot right behind the valve stem opening or it will not mount properly.
TIsTAN is online now   Reply With Quote
Old 04-13-2005, 11:33 AM   #8 (permalink)
EPTITAN's Avatar
Location: some where between bum f&*$ Egypt and you got a pretty mouth
Haven't had a problem with mine except when I first got them I had to change the rubber grommet on a couple to stop the leak I had. All is good since, about 5,000 to 6,00 miles so far.
EPTITAN is offline   Reply With Quote
