Old 06-02-2005, 08:14 PM   #1 (permalink)
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
Perma-Cool Bolt-On Oil Filter Adapters
what are these used for
is it just for bigger filters.....
http://store.summitracing.com/defaul...earchType=Make
import2nr is offline   Reply With Quote
Old 06-03-2005, 07:19 AM   #2 (permalink)
SickWhip's Avatar
You should get a direct link.
Old 06-03-2005, 09:47 AM   #3 (permalink)
import2nr's Avatar
http://www.perma-freeze.com/Catalog/Cat_page28.html
Old 06-03-2005, 10:01 AM   #4 (permalink)
Banned
JayDee's Avatar
Send a message via AIM to JayDee
Originally Posted by import2nr
You use the same filter you currently use, but this sandwiches between the filter and the motor. It has two ports, an IN and an OUT. This allows you to run the oil through an oil cooler.
Not a bad idea if you tow HEAVY.
JayDee is offline   Reply With Quote
Old 06-03-2005, 10:19 AM   #5 (permalink)
import2nr's Avatar
ahaa
thanks
Old 06-03-2005, 10:20 AM   #6 (permalink)
SickWhip's Avatar
Ask and you shall receive! Thanks a lot!
