Has anyone installed an aftermarket transmission cooler. I'm just looking for suggestions. Everything in the truck appears to be fairly heavy duty but I've read several comments on Trans temperatures being rather high when pulling heavy loads. I just want to avoid that situation and would rather take some advice instead of having to be the explorer.
1. It comes with a transmission cooler. If you have the Big Tow package you also have a temp gage.
2. All the posts I have seen regarding high temps resulted from trying to tow in too high of a gear.
I think I tow one of the larger loads on this site (8000-lb travel trailer) and my tranny never showed signs of getting hot on our last trip to Malibu. I have the Big Tow and towed in 4th gear with the tow mode on.
That knob is really a plastic plate. It pulls out. My B&M 2 1/16 gauge fit in it perfectly. I bought a 2 1/16 drill hole saw at Ace Hardware and hand turned it from the inside. Then I clipped the extra plastic off the B&M retaining ring and snapped it all together. It looks better than factory! I am halfway through the installation. I need to know which steel transmission line is the return from the cooler. This kit seems made for the XE Titan. Or any non-4wd without the Tow package.
blueskys,
I installed a Cyberdyne LED trans temp gauge last August. I put it on the output line going to the cooler. Those steel lines are 10 mm, NOT 3/8". Make sure you have the correct fittings BEFORE you cut the line, because they are hard to find.
I am SOoooo glad you told me that! I would have never guessed they are metric.That would have certainly ruined my Mexico road trip this weekend.
The power of forums comes through.
