Old 09-09-2005, 11:33 PM   #1 (permalink)
Sirius install
I just checked w/ a local dealer to see what it would cost for the Sirius tuner and the installation. They quoted me $570 plus tax. Does that seem about right? Does anybody think it's worth it, or is it better to go aftermarket?
jkiller5150 is offline   Reply With Quote
Old 09-10-2005, 12:09 AM   #2 (permalink)
chepdog's Avatar
Go aftermarket, check mine out, cost me $45.00
sirius-install-family-pictures-199.jpg  sirius-install-family-pictures-200.jpg  sirius-install-family-pictures-201.jpg
chepdog is offline   Reply With Quote
Old 09-10-2005, 12:27 AM   #3 (permalink)
ruauman2's Avatar
Here is my install. $50 for the receiver and $5 for the mini to mini cable. The only problem is to operate the remote control you have to lift it up to hit the IR port on the receiver because the front edge of the dash is in the way.
If I hear the lyrics to "Macarthur Park" one more time, I swear to God I'm gonna go postal!!!
ruauman2 is offline   Reply With Quote
Old 09-10-2005, 12:38 AM   #4 (permalink)
Old Speed's Avatar
i dont have any photos right now but i put in my kenwood deck with sirius a while ago ran the wires to the decoder box, i put under the drivers seat, then ran the antenna out of the 3td highmount brake light! worked great
05, Smoke titan, SE, king cab,w/ big tow pakage
Old Speed is offline   Reply With Quote
Old 09-10-2005, 07:49 AM   #5 (permalink)
I went with a Sirius Starbase unit. It was more exspensive $149.99, however the small footprint seemed to fit better in the truck IMHO.
Below is the link to a thread with more pic's.
Sirius Starbase
'05 Titan KC SE 4x4 - Canteen - BOD 3/05 | K&N CAI
usulsuspct is offline   Reply With Quote
Old 09-10-2005, 10:45 AM   #6 (permalink)
I don't know what stereo you have. Assuming you already have the pre-wire cable, the antenna + OEM tuner is $355.00 here:
http://www.grubbsperformance.com/Mer...uct_Code=999U9
The install is not worth $200 IMHO as you can easily DIY in about an hour, even if you go slow.
Simple install instructions (if you don't have a column mounted shift):
Photos of simple XM install
You can roof mount the antenna through the third brake light, I think it takes a deep 7 mm socket.
As far as OEM v. aftermarket, you have to decide if the integration (mainly steering wheel controls and not having to wire through the AUX jack) is worth the extra $. Another factor, I think the aftermarket units may have better displays than the OEM.
Old 09-10-2005, 08:23 PM   #7 (permalink)
Another thing to consider is the antenna. The new SIGMA (Sirius Inside Glass Mount Antenna) is proprietary to Nissan and Toyota receivers. The plugs on the antenna's splitter may not be compatible with other brands of receivers. You won't find it at Crutchfield or Best Buy.
If you've got no problem with a roof mount antenna, then aftermarket offers many receiver options. The install that usulsuspct did (post #5) is awesome!
Jamie at TitanParts247.com offers the receiver/SIGMA/brackets for about the same as grubbs.
If you install the receiver yourself, you don't need the brackets (about $13) - mount the receiver on the knee bolster, just below the steering column. One of our members posted several pics of this - search on "sirius" or "sat radio" to find them. The brackets are for sandwiching the receiver in between the RF amp and body control module way up on the firewall, above the accelerator. I studied that arrangement for about eight seconds, threw my brackets in the trash, and put the receiver on the bolster. I can see how a dealer's labor charge would be high, just for this reason.
I really enjoy having Sirius. I've never heard XM, or looked closely at a program guide.
Either way, you won't regret it.
Jim in NH
Copper LE CC (mine)
Born 2/25/04. 4 WD, Big Tow, Nissan Hood Protector, Weatherflectors, Truxedo LoProfile, PIAA 1500 Backup Lights, CompuStar Remote Start, OEM Sirius & Sigma antenna, K&N drop-in.
Galaxy SE KC (son's)
Born 5/10/04. 4 WD, Big Tow, Popular Package w/captains, Utility Bed, Weatherflectors, Truxedo LoProfile, PIAA 1500 Backup Lights, CompuStar Remote Start, K&N drop-in.
jburson250 is offline   Reply With Quote
Old 09-11-2005, 11:38 AM   #8 (permalink)
Supporting Vendor
P's Titan's Avatar
Sirius Starbase
DONT waster your money on the stock. Look at some people's installs on here and figure for yourself. I personally think usulsuspct's is the best I have seen.
I am getting this one and it comes with everything you need in the kit for $150. Forgot to mention that usulsuspct
my mods list
www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 09-12-2005, 03:50 AM   #9 (permalink)
msp2928's Avatar
Question 3rd Brake Light Install
Can someone explain the 3rd brake light antenna install.
msp2928 is offline   Reply With Quote
Old 09-12-2005, 03:55 AM   #10 (permalink)
TexasTitanXE's Avatar
Send a message via Yahoo to TexasTitanXE
msp2928 - If you look at the ceiling near your back window in the center you will see 2 round gray caps. Pop those out and you will a 7mm nut on each side. You will need a deeeep 7mm socket to remove. Then you can pop out the 3rd brake light. Then it is just a matter of routing the SAT antenna wire from the dash back to that opening. Not too hard. There have been multiple postings on this subject - just do a search. I would hook you up with a link but I am not sure how to do that??? I installed my Nissan Sirius box and Terk Mini antenna myself with very little difficulty. David.
KC XE 2x4 Constructed & Purchased in March of 2004, Preferred Package, Nissan OEM Fog Lamps, OR Wheels, DeeZee Tool Box, Nissan Sirius Box, Terk Mini antenna, Nissan Receiver Hitch+Houston Astross Hitch Cover, Interstate MT34R Battery, Bridgestone Dueler A/T Revos P285/70TR17, GM Style CCLs, ~92K miles,GM Style Cab Clearance Lights, Drug Information in Lay Language.
TexasTitanXE is offline   Reply With Quote
Old 09-12-2005, 06:57 AM   #11 (permalink)
ruauman2's Avatar
Do a search on '7mm' and then look for Eakes comments.
Old 09-12-2005, 07:23 AM   #12 (permalink)
the OEM unit is nice for control, but I have one permantly installed in my jetta. The truck is a plug and play that I can use in the house too. I got a bracket (that needed just a little modification to fit. that mounted it right next to the radio controls on the passanger side. I routed the wires neatly and use the cig port on the passanger side. Its clean and I didnt have to beat up the interior which was my goal with my trucks.
JamesB is offline   Reply With Quote
Old 09-12-2005, 11:21 PM   #13 (permalink)
raxton's Avatar
you do it like this...
-info-
04 Titan LE CC 4x4 - Smoked n Loaded
raxton is offline   Reply With Quote
Old 09-13-2005, 01:42 PM   #14 (permalink)
phlydude's Avatar
don't install a Sirius, get an XM unit!
As for aftermarket or OEM, go aftermarket. It's cheaper, it has a better display, and it will usually come with a remote control.
I do Blu, do you?
phlydude is offline   Reply With Quote
Old 09-13-2005, 05:38 PM   #15 (permalink)
raxton's Avatar
howard stern sirius > xm
