Old 09-14-2005, 11:40 PM   #1 (permalink)
Grille overlay install help please.
I just got the Mr. Grille 3 piece upper and 1 piece lower grille overlay kit and I have numerous stupid questions. (and yes, I have done a search already)
1. Just how, exactly do you get the upper stock grille off?? ( I see clips and I see these two little plastic panels that pop off on top of the stock grill, do these mean anything?) Not sure exactly how to get this thing off without breaking $hit.
2. I am guessing that you have to take the upper stock grille off and install the lower "bumper" grille insert FIRST correct?? ( this thing uses zip ties to connect )
3. HOW do you remove the Nissan badge from the stock upper grille?
4. Do you like the replacement grille better with or without the Nissan badge put back on it ( I guess with double faced tape?) This grille has no "cut-out" for the badge.
I think I know how to attach the new grille to the stock one. But am unsure as to how to UNinstall and REinstall the stock grille........
THANKS FOR ANY HELP!!
'04 Black LE 4x4 Crew Cab, Big Tow, Volant CAI, Flowmaster 50 series dual exhaust, Tekstyle low-pro tonneau cover, 20 inch chrome Eagle Alloy wheels, Mr. Grille billet grille, Xm Sat radio, Nissan all weather floor mats, Armada front bumper air dam (painted black).....Truck is gone!! Traded for 2006 Maxima in 5/06.....Titan's RULE!...(gas prices were killin' me)
PENROSE is offline   Reply With Quote
Old 09-15-2005, 12:33 AM   #2 (permalink)
Awesome.... Thanks!
Old 09-15-2005, 12:51 PM   #3 (permalink)
sandogtitan's Avatar
Well, if you haven't figured it out yet, you have to take off the little plastic panels off the top of the grille under the hood. Then there are (I think) 8 little flat head screw clips. Turn those a 1/4 turn and slide the clips out from the inside (next to the headlight) give it a good pull and off it comes. Now, to get the emblem off the old grille, I used a hairdryer to heat up the glue and some dental floss to cut in between the emblem and grille and using a sawing motion just work it back and forth and the emblem will pop right off. To get the emblem back on the new grille, get some 3m double back sticky FOAM TAPE. Peel the old tape off the back of the emblem, alcohol or nail polish remover work wonders, using a dremel tool, cut off the two alignment posts, install the new tape, and install the emblem, I aligned mine by counting the vanes from the top to the the bottom, finding the center and then making sure the sides are on the same billet line and BAM!!! You have a killer grille. To reinstall the new grille put the clips on it first, then line it up and pop it on, it only take a little pressure and it will pop into place. Got some pics for ya on another thread. Good Luck.
How to install Nissan emblem to aftermarket grille?
2004 Titan SE 5.6L V8
Deepwater Blue
Volant Cool Air Intake w/snorkel
Flowmaster Custom Exhaust
Bed Extender
Better Built Tool Box
Utility Bed Package
BIG TOW Package
Billet Grille.
"The Titan is stomp on your tea party, kick your dolly in the teeth, tough!"
sandogtitan is offline   Reply With Quote
Old 09-15-2005, 04:52 PM   #4 (permalink)
I used some kind of insturtions I found on here. I cant remember them all, but sounds like sandogtitan has them right. Take your time with the wierd bottom clip/screw things, you dont wanna drop them and never find them again...
I chose the no-emblem look...
Good Luck!
SmokenTitan is offline   Reply With Quote
Old 09-15-2005, 06:15 PM   #5 (permalink)
gr8titan's Avatar
Enclosed is a copy of grill removal instructions by "Carriage Works". I found it very helpful and simple when I installed my first grill mod. You'd need a wide flat screwdriver. Hope this helps.
gr8titan is offline   Reply With Quote
Old 09-15-2005, 08:16 PM   #6 (permalink)
mtbendo's Avatar
Dang, instructions that you can actually see what's in the picture! What a concept! The Grille4U instructions were so dark I could make out what was what.
The two clips on the very ends are the hardest to get at. Take your time.
04 Galaxy Black Crewcab LE/Big Tow/Off Road/Nav/DVD
Hood Protector/Gibson SS Extreme Duals/Leer XQ Shell/AEM Brute Force
KC Backup Lights/Stainless Steel Grille/Chrome Tailgate Trim/PRG Mini Lift
mtbendo is offline   Reply With Quote
Old 09-15-2005, 09:30 PM   #7 (permalink)
thanks guys
Old 09-15-2005, 10:28 PM   #8 (permalink)
Also, be careful not to break the little dang clip pieces, I've broken two so far, they are really brittle.
Deepwater Blue
Bed Extender
Utility Bed Package
BIG TOW Package
Billet Grille.
Old 09-18-2005, 12:49 AM   #9 (permalink)
It's a done deal. Not that hard after all. Pics coming soon. Thanks again guys.
