Old 09-24-2005, 02:00 PM   #1 (permalink)
Westin running boards too low
I just installed some Westin Sure-Grip running boards on my Titan. I think that the brackets are too long and result in the running boards being too low. I'm thinking of contacting the vendor or manufacturer. Do they seem too low in the attached picture?
glennk is offline   Reply With Quote
Old 09-24-2005, 06:34 PM   #2 (permalink)
gr8titan's Avatar
I think they are have the same ground clearance as the OE nerf bars. Check the pic of my nerf bars below and compare it to yours.
gr8titan is offline   Reply With Quote
Old 09-24-2005, 06:57 PM   #3 (permalink)
Thats what I'm afraid they'll tell me. I think it looks okay for nerf bars to hand below the truck but I've never seen running boards with such a large gap from the lower body. Another thing is this picture on Westin's web site of a Nissan application is what I expected. Doesn't the picture appear as if there is no gap? I think my Titan looks horrible now.
Old 09-24-2005, 08:07 PM   #4 (permalink)
rjspitz's Avatar
Yeah, that's low. It should hug the rocker panel.
Old 09-24-2005, 08:24 PM   #5 (permalink)
mudfinder's Avatar
yeah, i think that' way too low. maybe wrong brackets were sent?
05' Nissan Titan SE CC 4x2
SE Popular Captains Package
Rockford Fosgate
NISMO CAI
JBA Catback Exhaust
DR Coilovers / PRG 1" Rear Lift Block
285/65/18 Nitto TerraGrapplers
305+HP and 379+lbs per ft of BALLS
mudfinder is offline   Reply With Quote
Old 09-24-2005, 09:28 PM   #6 (permalink)
The box for the brackets does say it's for a Titan. Anyway, thanks for the replies, you've confirmed my feelings. I decided to contact Westin since it's not the vendor's fault as the box says it's for a Titan. I'll share the results.
Old 09-24-2005, 09:32 PM   #7 (permalink)
rjspitz's Avatar
Good luck. Westin sent me the wrong step tubes before, but I ordered through a vendor. The box had the right part number, but the part in the box was wrong. Westin wouldn't deal with me. I had to use the middle man (vendor). Needless to say, it was more involved than it needed to be. Total swap-out took 4 weeks. Hopefully this won't happen to you.
Westin's reply was that the wrong parts were put into an entire batch of boxes. Maybe this was the case with you.
Old 09-25-2005, 08:20 AM   #8 (permalink)
baseballfanz's Avatar
Yeah that don't look right, nerf bar OK but that's just to low, that big gap don't look right.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is online now   Reply With Quote
Old 09-28-2005, 10:02 PM   #9 (permalink)
Here's the update...
I contacted the technical group at Westin and got the design specs for the bracket. Unfortunately, the brackets appear to match the design specs. The kit comes with some rubbery plastic strips that the instructions say are optional. I thought the strips were for providing a seal between the boards and the body, but apparently they are intended to cover the gap. I'm very disapointed with the kit.
I'm thinking about having the brackets shorthened to raise the height of the boards and close up the gap. The main length of the brackets are a constant width, so I think that an inch could be cut out and the two ends welded together. Can someone recommend a type of shop for the work? Would an auto-body shop be good to do this?
Thanks
Old 09-29-2005, 05:57 AM   #10 (permalink)
rjspitz's Avatar
That sucks. Anyone with a MIG welder can hook you up, body shop, most machine shops, welding shops. Just look up welders on your google local pages. Shouldn't cost more than $15.
