Old 09-26-2005, 02:57 PM   #1 (permalink)
Send a message via AIM to aguilar82082
power windows switch
Does anyone here know's where can i get both the passanger side and the drivers side switch. i have an xe with no power windows and i got that universal power window converter, but want the actual switches.
Thanks
aguilar82082 is offline   Reply With Quote
Old 09-26-2005, 03:33 PM   #2 (permalink)
rjspitz's Avatar
www.nissanpart4u.com
Click on the replacement parts search button.
Old 09-26-2005, 05:15 PM   #3 (permalink)
I don't know how the universal power window converter works as far as what amp capacity switch is required. Maybe they are just switching a trigger lead for a relay? I think the OEM switches might just be switching very low amp signal wires that send a signal to the Body Control Module. Hopefully they are rated to switch sufficient amperage for your purpose.
Old 09-27-2005, 02:40 PM   #4 (permalink)
search. I think pciley tried this and couldn't make the switches work on the aftermarket windows. probably, they do not handle enough amps anyway. the aftermarket windows take a 25 amp fuse and thats a bunch. you better just get one of the switch kits. I did get the "bmw" type and they look good and work good.
juma
