Thanks for the quick responses. My issue is that the twist clips located at the bottom of the upper grille cannot be accessed unless I put my hand through the opening where the lower grille goes. If I cover it, then I won't be able to twist those, ultimately leaving me in a position where I couldn't get the upper or the lower grille off. So the way I have it now, I have the twist clips on the top 4 spaces of the upper grille, none on the sides of it, and the bottom 3 are the click ones. (Taken from the sides)
The bottom grille is also giving me a bit of a pain, since the rubber molding comes off when I install it... not to mention I'm unsure just how much I should tighten it down.
