Utili-Track Install? - Nissan Titan Forum
post #1 of 5 (permalink) Old 12-03-2005, 04:37 AM Thread Starter
iTrader Score: 2 reviews
I've been searching for someone that has installed the rails after buying the track, but have had no luck. Specifically I'm looking for what the part #'s are on the spacer, weld nut, and plastic keeper....
cswake is offline
Advertisement
post #2 of 5 (permalink) Old 12-03-2005, 04:59 AM
iTrader Score: 4 reviews
Re: Utili-Track Install?
An alternative:
http://cgi.ebay.com/ebaymotors/RIVNU...spagenameZWDVW
bestatchess is offline
post #3 of 5 (permalink) Old 12-03-2005, 10:06 AM Thread Starter
Is that the specific set I'm looking for and could use in the install?
cswake is offline
post #4 of 5 (permalink) Old 12-03-2005, 10:39 AM
I think they were using 8mm X 1.25 but you would need to measure first and count how many. That set is just an example. You would need a tool and the correct number and size of pieces. Maybe this:
http://cgi.ebay.com/ebaymotors/NUTSE...8774QQtcZphoto
Of course it would be better to borrow the tool off somebody as I don't think you would be using it much.
post #5 of 5 (permalink) Old 12-04-2005, 07:04 AM
loufish's Avatar
iTrader Score: 11 reviews
2 things:
First, most riv-nuts are not flush with surface they are set in, unless you can find counter-sunk ones(very hard to find)
Second, the bed is actually different with the uni-trak option...
PRG Performance Kit w/SAW's
Rear Bumpy-Bumps
35" General Red Letter Grabbers on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
loufish is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Utili-Track Tie Down Cleats and Track Stops TITANUP04 Buy/Sell 6 02-02-2008 08:30 PM
Utili-Track Seating? Venom Titan Parts & Accessories 20 07-30-2006 09:16 AM
utili track tool box kongmen Titan General Discussion 16 07-24-2005 06:55 PM
Can you get aftermarket Utili-track for the bed? NewTruckGuy22 Titan General Discussion 6 05-30-2005 02:01 PM
anyone with utili-track? D'sT Titan Parts & Accessories 16 09-09-2004 06:52 PM
You may post new threads
You may post replies
