To install the bumper grill I am suppose to remove the stock plastic shroud.
I can't seem to get the darn thing off. I tried taking out the mounting tabs on the top part, but then I can figure out how to get the bottow part loose or out.
Any of those who have installed a bumper grill and removed this have any help?
I just fiqured this out yesterday, they are 6 nuts holding it on. I used a 1/2 inch socket. 4 on the bottom and 1 on each side. PITA if you ask me, and I broke 3 of the plastic bolts on the bottom putting it back on.
How did u even get a ratchet in there to get them out?? I couldn't even see those bolts looking from under the truck?
I pulled the top grill, and the skid plate. I had to use a shallow socket and a real small extension, and a small ratchet. It is a real PITA. Unless you want to pull the bumper it will be hard.
thanks. seems that i'll try to get it out, otherwise, i'm gonna try to improvise and see if I can do it with the scroud on it...
I just used a box-end wrench fished down between the bumper and the shroud. It wasn't easy - ripped up the back of my hands on the edges of the bumper, but those taper nuts on the plastic only needed a few turns with the wrench and they turned by hand. PITA no matter how you look at it...
