Old 04-17-2006, 07:25 PM   #1 (permalink)
Banned
ChicksDigEmToo's Avatar
How to remove TOW mirror caps!
Ok...today I spent the day looking for someone that had posted on removing the big tow mirror back cap. There was enough information on the regular mirror...but the Big tow mirrors were not the same! I decided to post this in case anyone should need it for refrence.
...with a lot of pain and frustration I got these covers off without tearing apart the truck!
There are two clips on each side of the mirror. Here's a link to my photo bucket with pictures (taken in the dark).
After I figured out where the clips are...it wasn't really that hard. You just had to figure out which way they unclipped... the pictures should help.
If you look at the backside picture...you will see where the clips are place in relationship with the mirror. I took some pics from the front so you could get and ideas of where to place your screw driver and the best angle to get to them.
Start with the bottom clips first. It seems that that takes the pressure off the top ones which were harder to get to. Here's the trick...if you look at the caps picture (the one showing the inside of the clip) you will see which way the tabs need to be pushed. The inside tabs (closet to the truck) get pushed up, the out side tabs get pushed away from the truck!!! Good to know trust me as you cant actually see what you are doing! Get your flat head screw driver in place as shown in the pictures for each clip. The tabs closest to the truck are further back behind the mirror. The outside ones are closer to the front of the mirror assembly. This is also good to know as you most likely will over miss the tab if you reach too far back! I hope this helps you!
ChicksDigEmToo is offline   Reply With Quote
Old 04-17-2006, 07:59 PM   #2 (permalink)
TitanicDJ's Avatar
Send a message via MSN to TitanicDJ
Re: How to remove TOW mirror caps!
Hey Chicks....
So I was just out there doing the same thing but it's getting to dark. So you move the mirror up all the way and the smaller mirror towards the inside. Then can you see the clip? Sounds like you just need to get the first off then the others come off easy?
DJ
'04 White SE, CC, BT, Off Road 4x4
• Banks Monster Exhaust • Pro Comp 6" Stage II • PRG Radflo External Reservoir Coilovers w/King Springs
• PRG OR Traction Bars • American Racing Chamber w/Teflon 17" • BFG T/A KO 315/70 17 • Active Tuning Grounding Kit
• FramBoost Air Intake • XM Satellite Radio • Hoppy Assist Tailgate • Grillcraft Black Mesh Grille • 2° Timing Advance
________________________
TitanicDJ is offline   Reply With Quote
Old 04-17-2006, 08:14 PM   #3 (permalink)
Banned
The only one you actually see is the bottom inside corner one. everything else is a feel for all! Start with that one and look at the placement of the screw driver to figure out where the others are.
Old 04-17-2006, 08:18 PM   #4 (permalink)
TitanicDJ's Avatar
Thanks.....tomorrow morning project.
DJ
Old 04-17-2006, 08:19 PM   #5 (permalink)
Banned
DJ
LOL...I'm with you...its a PITA. Getting the bug juice off mine now!
Old 04-17-2006, 08:21 PM   #6 (permalink)
TitanicDJ's Avatar
but i bet the chromes ones show more bug inners...hahaha
Old 04-17-2006, 08:30 PM   #7 (permalink)
rcantu's Avatar
can you see the part #'s on those black covers? I want to replace my chrome w/ black.
pics of the Titan
Old 04-17-2006, 08:33 PM   #8 (permalink)
Banned
right# 1407000RH
left# 1407001LH
Old 04-17-2006, 08:49 PM   #9 (permalink)
rcantu's Avatar
thanks. i already broke a clip from my chrome ones so i can't trade them.
Originally Posted by ChicksDigEmToo
right# 1407000RH
left# 1407001LH
pics of the Titan
Old 04-18-2006, 07:43 AM   #10 (permalink)
TIsTAN's Avatar
nice, appreciate all the info!
here is pic of the inside hooks on the chromed caps,
http://www.courtesyparts.com/Merchan...Code=A60-CHRTW
TIsTAN is offline   Reply With Quote
Old 04-18-2006, 10:23 AM   #11 (permalink)
Elbo's Avatar
Send a message via MSN to Elbo
This brings up a good way to get turn signals into the Big Tows, get a nice turn signal off a F250 or some other set of LED turns that would work, get a second set of housings to do the surgery on, get dremel, mark the spot for the LED's dremel away.
Elbo is offline   Reply With Quote
Old 04-18-2006, 10:24 AM   #12 (permalink)
rcantu's Avatar
well i found out you can't order the black caps. it's part #'s for production not for resale.
Old 04-19-2006, 11:31 AM   #13 (permalink)
ablexus's Avatar
Send a message via AIM to ablexus
Hey, uhm, did you want to trade? I like the look of the chromies... direct swap or no?
Andrew
A.K.A. Whore Without A Cool Whore Name
Here's my truck and an angry little force-fed 4-banger:
12 cylinders, 650 hp, 700 tq. Lamborghini, eat your heart out.
ablexus is offline   Reply With Quote
Old 04-19-2006, 11:33 AM   #14 (permalink)
rcantu's Avatar
you have big tow mirrors? your tiny sig pic looks like regular ones to me.
Andrew
Old 04-19-2006, 01:27 PM   #15 (permalink)
ablexus's Avatar
Yeah they're regular but I haven't examined the big tow mirrors up-close... I am inferring that they aren't direct swap. Nuts.
Andrew
XE Mirror Caps and Handles FFtitan Buy/Sell 11 01-11-2006 04:24 PM
WTT - XE black mirror caps zimmy0615 Buy/Sell 0 12-30-2005 04:18 PM
chrome mirror caps..... berliner Titan Parts & Accessories 0 10-26-2005 09:28 PM
FS: Chrome mirror caps QWIKWHIP Buy/Sell 22 11-22-2004 07:06 AM
