Re: bed power outlet
Here are the cheapest power inverters I have found.
http://www.heartlandamerica.com/brow...A-07B8EEC59D56
Ive got a 2500 watt that I can run a small portable AC unit with. I put the AC unit in the tent!! It is not to smart to switch out the jumpers with a cig. adapter. Even if it does work you are going to burn the internal wiring in your truck if you put to much load on it, or the inverter will just overload. It can only draw so much wattage (usually up to 250 watts) out if the cig adapter. I also have a 500 inverter that if I want 500 watts I have to install the jumpers to the batt. or I can use the cigg. adapter to power up to 250 watts.
