I have had it on for about a month now and really like it. Along with my Banks the increase in power is pretty damn cool. I don't know what the numbers are but it's more than before. Gas milage I haven't seen an increase yet just because I'm on it a little more just to hear it
It does have a slight whistle in the lower RPM's but I don't mind. Install was pretty straight forward. The only issue was peeling back the fender liner to get to the lower bolts but I had help and did it the right way.
The FramBoost and the AEM are the same intake. Fram makes the filter and AEM makes the intake. difference is in the color. AEM's intake tube is silver while FramBoost is a kind of gunmetal. Both the FramBoost and AEM are also a dry systems so you wont have any issue with MAS sensor that would with the others that run an oil filter.
Here is a link to there limited lifetime warranty:
http://www.framboost.com/images/lim_warranty.pdf
It's also designed to be consistent with vehicle manufacture's warranty-every system is in absolute compliance with the guidelines of the Magnuson Moss act.
Do a search and you'll find a lot of info on the install for both the AEM & FramBoost.
DJ
'04 White SE, CC, BT, Off Road 4x4
• Banks Monster Exhaust • Pro Comp 6" Stage II • PRG Radflo External Reservoir Coilovers w/King Springs
• PRG OR Traction Bars • American Racing Chamber w/Teflon 17" • BFG T/A KO 315/70 17 • Active Tuning Grounding Kit
• FramBoost Air Intake • XM Satellite Radio • Hoppy Assist Tailgate • Grillcraft Black Mesh Grille • 2° Timing Advance
________________________
